Old 05-13-2012, 09:16 PM   #1
fast murray's Avatar
Attn. Satellite Gurus
I have a SD directv reciever that lives in our RV. I also have one of the slimline dishes that they are using for HD reception laying in the shed. Will the slimline dish work to recieve SD channels on the older SD reciever?
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 05-13-2012, 10:15 PM   #2
rracer5's Avatar
You should if you can change the setting in your receiver to the Slimline. Then type in your zip code of where you are to get the elevation for the slimline. It is probably different than the 18" round SD dish because of the difference in their shapes.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 05-13-2012, 10:47 PM   #3
JDWeir's Avatar
I use a slimline dish and it will also pick up the SD channels. At my home, I had both HD and SD receivers with the slimline, so I just brought the entire set up with me when I went full time.
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline   Reply With Quote
Old 05-14-2012, 05:40 PM   #4
Good point on changing the settings on the reciever. I think I'll try to find an 18" dish as that's what we use when we are on the road. I am going to permanently mount a dish on the building that I park next to at home so hooking up at home would be as easy as connecting the wire. Thanks for the feedback.
2004 Wildcat 28BH
