Old 01-09-2011, 03:30 PM   #1
Audio Video hook up
Hello, I need help in how to hook up these components so everything works.
See photo below
1.Top Box is the Direct TV box.....
2.Next is the switch box which came with RV
3.Next is the Executive DVD and FM radio player which came with RV and I need it for the surround sound system.
4.Next is the NEW DVR, and VCR recorder and player, since I don't have the Direct TV DVR I purchased this to do the same thing.
I have 3 outlets in the upper right cabinet.
One is for up to 6 power cords, the second is for two coaxial cables, one says
from Dish ( ot sur if this means Dish TV or what.) the second says Roof Atenna.
Next to that is a switch that turns the automatic satillite on and off.
Now how do I put this all together to make everything work.
Thanks....Joe
2008 Georgetown XL 378TS
JDickson is offline   Reply With Quote
Old 01-09-2011, 07:02 PM   #2
sherdep's Avatar
you see the red and white are for audio and the yellow is for video
The outputs connect to the inputs
Everything has to be turned on for the way I am telling you to hook it up for it to work right
The Coax that says From Dish (Must have Dish Hooked up and not sure where that is at on your trailer) goes to the Direct Tv box Coax Input
Direct TV output goes to the Input on the NEW DVR, and VCR recorder and player
The DVR Output goes to the Input on the Executive DVD and FM radio player
The Output from the Executive DVD and FM radio player can go to the Switch Box
Roof Antena can go to the switch box
When switched to the Roof Antenna it will not do surrond sound unless it is routed to the Executive DVD and FM radio player
Hope that gives you some sort of direction or help to get you where you want to be
If all else fails try hooking up the outputs to the inputs and test to see what it does and it if is what you are trying to accomplish - without being in front of the equiptment and being able to really see the labels it is very hard to give you accurtate advice on how to hook it up
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
