Old 11-21-2009, 03:09 PM   #1
RV Newbie
Automatic Generator Starter (AGS)
I am considering having a RS3000 installed my Georgetown. The RS3000 can actually be installed inline for 50A service requiring no subpanel. I am concerned, however, about the possiblity of accidentally attempting to operate my rooftop AC units on the inverter. I found that Xantrex also sells an Automatic Generator Start (AGS) module. This module apparently can start the generator from a thermostat signal which is very cool! Does anyone on this forum have such a system installed? I am primarily concerned about the compatibiliy with my roof top AC units. I actually do not have a conventional thermostat but rather a remote control that apparently accesses the thermostats persumably in the unit. I am a little concerned whether or not this type of system can be wired in to communicate properly with the AGS. Any help would be greatly appreciated.
AllenCrabtree is offline   Reply With Quote
Old 11-21-2009, 04:43 PM   #2
NWJeeper's Avatar
Personally and this is just me talking here but I would NEVER want that generator running unless I started it myself. I don't see the need for this feature on an RV.
Ed & Wendy
www.nwjeepn.com
Old 11-22-2009, 07:13 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
I have the RS3000 in my Georgetown 370. The AGS is a nice feature where you predetermine at a particular loss of battery voltage the generator starts up to recharge the batteries. It also can be set to come on when it senses a predetermined load. I prefer to manually turn on the generator when using the AC units or microwave. Mine is not wired into the t-stats though.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 11-22-2009, 09:54 AM   #4
This past summer we spent a week-end (3 nights) camped right next to a large motorhome with an auto generator. The thing turned on and off intermittently all night long, every night. Not overly loud, but as I am a light sleeper, it got real old real fast !!!
...VTX-AL
VTX Al is online now   Reply With Quote
Old 11-22-2009, 11:45 AM   #5
NWJeeper's Avatar
...VTX-AL
I might add that most RV parks have a strict no generator policy. I have seen where guys leave too much load on in their rigs and leave for the day, blowing the circuit breaker on the post and loosing power. In this case a generator starting on it's own may just get you the boot out of the park when you return.
Ed & Wendy
www.nwjeepn.com
Old 11-22-2009, 02:35 PM   #6
RV Newbie
I was not planning on using the AGS when in a RV park. I am not a serious dry camper and would not want to disturb my neighbors if I were. I am primarily looking for an inverter for light loads while traveling down the road. As the RS3000 can be installed inline for the entire 50A service with no subpanel there is a risk that someone (my wife) could forget and turn on the rooftop units while traveling down the road. I do not really have any desire to run my AC's off of the inverter so I thought the AGS would be a good accessory that could automatically start the generator when it detected this new load.
Old 11-22-2009, 03:12 PM   #7
RV Newbie
cfsoistman,
I wonder if the current draw of the blower fan would be enough of a load to start the generator? There is up to a 3 min compressor start delay whenever the AC unit turns on. This should give you plenty of time to get the generator starter before the compressor kicks in. I would think the larger overall load would be the compressor but I have never seen a break down on the current draw with the blower fan only. I would think that would work without having to wire in the thermostats. It is just not clear how I would wire my thermostats in if I wanted to. There is a thermistor on the ceiling unit tied to a control module that turns on and off the unit. I would think I could hack into the signal wire coming from the control module to the main unit but I don't feel comfortable doing that.
Old 11-23-2009, 06:05 AM   #8
cfsoistman's Avatar
...VTX-AL
Obviously that camper didn't use the quiet time function. Mine is set to not run between 10:00 PM and 7:00 AM. Of course I can't run my AC Unit and I restrict my use of current. It's the user not the product at fault.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 11-23-2009, 06:15 AM   #9
cfsoistman's Avatar
cfsoistman,
The blower motor doesn't draw much at all. I've ran mine on the inverter on occasion. If I know I'm going to need the AC unit to keep the coach comfortable I manually turn on the generator. I rarely have done so mostly because when I have a long distance to travel (8 - 10 Hours )I generally do it at night. I'll leave around 10:00 PM and take my time, stop at a couple rest stops along the way. However, if we're on our way back from the beach and traffic is bumper to bumper then the generator will most likely be running along with AC. My unit is set up to start the generator at 10 amps load. Most of the time without useing any AC units. The load is only 3 to 6 amps most times.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
