Old 01-10-2016, 04:07 PM   #1
Automatic leveling system
We just bought a new 2016 Sierra 5th wheel with the Level Up auto leveling system. We we trying to unhook from the truck and when we went to turn on the control panel to the system it will not come on. How can we get it on?
Capsmp96 is offline   Reply With Quote
Old 01-10-2016, 04:31 PM   #2
silly question but is your 12v master switch turned on?
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 01-10-2016, 04:36 PM   #3
Yes I am pretty sure it is. We just picked it up from dealer yesterday and everything was working. Went to unhook from truck today and panel would not come on. Any suggestions? Thanks
Old 01-10-2016, 04:39 PM   #4
Todouble's Avatar
Mine controller must be wired before the battery cutoff switch because it works regardless of battery cut off. But you may want to check yours anyway. I have to hold the power button for a few seconds on mine. Maybe a fuse out too.
Todouble is offline   Reply With Quote
Old 01-11-2016, 05:47 PM   #5
Major's Avatar
Also check the battery terminals. When we got our last RV, the battery terminals were so lose that the battery would not provide any power. Thought the battery was dead.
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
Old 01-20-2016, 06:14 AM   #6
BDavis's Avatar
The Sierra is similar to the Sandpiper. Mine is "hot" all the time. Should be able to just turn it on. There is a fuse for it as well as a fuse up at the hydraulic motor/pump.
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 01-20-2016, 06:45 AM   #7
TURBS's Avatar
Auto leveling should be directly wired to the battery.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
leveling
