Old 06-16-2016, 08:36 AM   #11
Mr havercamp: thank you very much for the follow up! I did speak with dometic and will be ordering the 8952002.400b.
franger1983 is offline   Reply With Quote
Old 06-16-2016, 12:26 PM   #12
Dahagen
I damaged my awning arm and found out that some RV repair shops that replace entire awnings because the fabric is bad save the arms and can make you a good deal.
dahagen is offline   Reply With Quote
Old 06-16-2016, 04:11 PM   #13
mkekflyers's Avatar
I needed a cover for my 9100 series..look on the inside of the forward arm. My sticker was on the inside of the lower arm, standing in front of the arm looking rearward the info you need is on that sticker. Then, use all that info on the web site find your parts..there are drawings in the detail for each major component that you can "pop open" by clicking on the assembly number on the left of the list...their customer service reps I've dealt with are pretty good at helping you make sure you get the correct stuff. I talked to them while looking at the screen so I made sure they knew what I was looking for...
2018 Georgetown 378 XL
2012 Ford Edge TOAD
Blue Ox & RVIBrake
2014 - 37; 2015 - 58; 2016 - 64;
2017 - 93, 2018 - 101
mkekflyers is online now   Reply With Quote
awning
