Awning LED lights
Hello all! We just bought a 2017 Cruise Light 30ft camper. Have only had it a couple months, used 3 times. The LED awning lights will not come on. Just started doing it. The multi colored remote will not turn on the white lights or the colored lights. The light switch on the master panel does nothing. The master remote that controls the slide out, jacks and awning has a light button on it, when you hit that button the lights flicker on then go out. I found the access hole in the master bedroom, made sure all the connections where good. Unplugged everything and retried. Same result. Changed batteries in the remotes, no change. Anyone else had this issue, trying to avoid taking in for service with holiday weekends coming up. Thanks for any help.
