Old 11-21-2010, 03:15 PM   #1
Axle Grease Fittings
I was doing a thorough pre-trip on the TT today, we are about to go on a 600 mile trip over the T-day holiday. I decided to grease the axles as per the instructions as we got the TT new in June and I hadn't greased the bearings after the several short trips we have been on. So I went to the auto parts store and bought the lithium bearing grease and a new grease gun just for the bearing grease. I start trying to put the grease into the grease fitting and it just keeps coming out from the end of the hose. I cleaned out the excess grease around the fitting and I see the problem, there is a piece of metal (not sure at this time what it is), so I use the screw driver and push it aside so I can fill it with grease. No problem, grease goes in. At the next wheel the metal is not in the way but grease is still coming out around the fitting (I'm thinking I got a bad grease gun). I push harder and the grease goes in. Now I move to the other side of the TT and pop off the cap and the grease fitting has fallen off and is laying in the bottom of the cap and there is very little grease around the inside of the cap. I got out the 5/16 socket and put it back on and tightened it up and put a good amount of grease in before it was full. BTW, I have now figured out what that piece of metal was I saw on the other side, it was the tail of the cotter pin for the axle. How did they get grease in after assembly? On to the last wheel, checked for tightness first and the grease fitting was also quite loose. Tightened it up and put in grease. Rechecked the tightness on the side I already greased and one on that side was loose and the other was tight. So out of 4 grease fittings on the axles, 2 were loose, one had fallen off, and one was tight. I could have averted a major failure on our first long trip by doing the checks outlined in the manuals. Please take a few minutes and check yours. I am not pointing fingers as maintenance is ultimately my responsibility.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 11-21-2010, 05:13 PM   #2
kz08h5's Avatar
I had similar problems with mine. I could not get any grease into the hub through the grease fitting. I remove one grease fitting and found that it would not accept grease. I bought new one and replaced all 4, grease went in with no problem. All the fittings were hand tight at best and one had come out completely. I now know that I need to look at them at least yearly if not more often.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 11-21-2010, 05:38 PM   #3
I looked at mine and the cotter pin is off center but I think it has a hole to screw in a fitting. I repacked my bearings but I am going to remove one wheel and put in a fitting and see if it takes grease. My book says if it has fittings it has a plug to remove to get to the fitting. Mine has the normal metal cap to remove to get to the cotter pin and nut.
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
Old 11-22-2010, 06:36 AM   #4
Herk7769's Avatar
My experience was:
1 fitting lying in the cup
1 fitting so loose there were one one thread holding it in.
No grease at all in all four hubs (other than assembly grease in the pre-packed bearings)
I used 1 full sized tube of grease the first time I greased them.
I think the dufus at the factory did not know they were the new "flow through" spindles. Someone must have just told him to screw on the zerk fittings and not knowing why he was doing it, just put them on hand tight.
My right front hub ran cool for the first time after I filled the hubs correctly.
My mistake was assuming:
1) The factory serviced the trailer prior to shipment
2) The dealer actually LOOKED that the hubs had been serviced as part of the dealer's acceptance inspection (I know it was "free" but jeeze they could have actually DONE one).
HAM CALLSIGN - KC3FFW
Old 11-22-2010, 09:25 AM   #5
Villa Estate 392FLFB
The_Stuff's Avatar
and people wonder how these trailers make the journey to the dealerships in one piece!
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 11-22-2010, 01:54 PM   #6
I had an RV shop check and fill the axle fittings. I still cooked one. I then had to get a whole new axle ($500 insatlled). So had the a new tailer dealer check the other side, suprise "no grease". So I asked to check the other axle, suprise "no grease". I shall not return to the first RV shop or dealer. So the real story is not to trust RV shops or Dealers unless you are standing on their shoulders.
Life is something to do when you've finished breakfast
Chuck & Margie
Both Retired
08 2500HD Silverado 6.6L Duramax
Flagstaff 829fkss
Round Mound of Sound is offline   Reply With Quote
Old 12-09-2010, 11:24 PM   #7
Retired US Navy Diver
I picked my new 2011 Flagstaff V-lite up 3 weeks ago in Oklahoma. Pulled it home to Longview, WA. The dealer assured me wheels had been torqued and during the trip I bought a new grease gun and lithium grease. Pulled off the grease covers and found presence of grease so didn't bother to add any more. Last weekend I pulled off the grease covers and greased the fittings. I also found the cotter pins bent over the grease nipples and also found the rubber covers over the grease nipples torn open by the cotter pins. I also found one nipple forced in cocked to one side (probably stripped or thread damaged). And several of the nipples where very hard to pump grease into. I will pull them tomorrow and replace and grease again. Also buy set of buddy bearing covers to protect bearings. Otherwise LOVE my new Flagstaff and the RV community.
gktsuda1956 is offline   Reply With Quote
Old 12-10-2010, 07:13 AM   #8
Herk7769's Avatar
Forest River are you listening?
This is a production line problem.
Also a dealer problem.
Thinking the acceptence inspection is just pure profit for the dealership to offset what they could have made on the sale in a hot economy.
Old 12-10-2010, 09:56 AM   #9
M109Rrider's Avatar
The Prime Time is the first trailer I've had with grease fittings. How do I tell if it's full?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 12-10-2010, 01:15 PM   #10
Herk7769's Avatar
Some rules with these things
1) MANUAL guns only. Slow pressure on the handle so you do not blow out the rear seals.
2) Pump until you see the old grease push through the bearings. If you, or any one else, has not done done this before; it will take a LOT of grease.
3) Wipe off excess old grease that was pushed out. Replace rubber boot.
axle
