Old 10-19-2010, 01:46 PM   #1
axle width
I need to know what the axle width is on a cherokee lite 26k?
wanting to make a concrete pad for the trailer to sit on at home ,and would like to do this before it gets delivered next week.
numbers is offline   Reply With Quote
Old 10-19-2010, 05:27 PM   #2
I can't help you with the cherokee lite 26K but most are 8 feet wide however newer units are going to a width of 102 inches 8'6" so make it wider than needed.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 10-20-2010, 02:39 PM   #3
thats not the axle width! thats the whole trailer width? correct?
I am looking for the width from center of tire on the left to the center of the right wheel, so I can make a pad for the wheels to set on when its at home! thanks
Old 10-20-2010, 03:18 PM   #4
Villa Estate 392FLFB
The_Stuff's Avatar
take that 8'6 and thats how far those 2 pads should be from outside to outside. make the pads 1 foot wide and you should be safe even at 8'8" apart
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 10-20-2010, 04:06 PM   #5
Just make it big... easier to hit when your backing up :-)
2011 Sierra 35 Loft TreeHouse
2006 Dodge 3500
Better Photo
Mowat is offline   Reply With Quote
Old 10-20-2010, 04:10 PM   #6
Thanks for the help! The outside of the trailer is only 8 feet and the wheels are under that!
Old 10-20-2010, 04:21 PM   #7
Dave_Monica's Avatar
So make it only 7.5' wide as you must be an expert at backing the thing up!
We're trying to be helpful...doesn't look like it's worth the effort!
Dave
Old 10-20-2010, 04:38 PM   #8
frankm's Avatar
Numbers, I like others that have responded to your question fail to see the reason for knowing exactly the axle width if you already know your trailer is 8'. If you have the yard space why not make the pad 8'6" or 9' wide that way you may have an easier time putting the TT on it. Plus it will give you a solid area to walk around the TT.
PS. If what you are trying to do is build two separate thin concrete pads for just the wheels to sit on then we all missed the question.
frankm is offline   Reply With Quote
Old 10-20-2010, 04:44 PM   #9
Not getting touchy, just looking for the correct info. I do appreciate your time and effort! Im not an expert at backing up, but have the proper location for trailer to be placed with ease. Sorry for the trouble and missunderstanding. Have a good day!!
Old 10-20-2010, 04:45 PM   #10
YES JUST 2 PADS i JUST GOT THE INFO I NEEDED IT IS 7'2" CENTER TO CENTER ON THE WHEELS!
axle
