10-19-2010, 01:46 PM
axle width
I need to know what the axle width is on a cherokee lite 26k?
wanting to make a concrete pad for the trailer to sit on at home ,and would like to do this before it gets delivered next week.
10-19-2010, 05:27 PM
I can't help you with the cherokee lite 26K but most are 8 feet wide however newer units are going to a width of 102 inches 8'6" so make it wider than needed.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
10-20-2010, 02:39 PM
thats not the axle width! thats the whole trailer width? correct?
I am looking for the width from center of tire on the left to the center of the right wheel, so I can make a pad for the wheels to set on when its at home! thanks
10-20-2010, 03:18 PM
Villa Estate 392FLFB
take that 8'6 and thats how far those 2 pads should be from outside to outside. make the pads 1 foot wide and you should be safe even at 8'8" apart
One state/province at a time!
Full Timing - Salem Villa Estate - 392FLFB - Purchased July 29th 2010
10-20-2010, 04:06 PM
Just make it big... easier to hit when your backing up :-)
2011 Sierra 35 Loft TreeHouse
2006 Dodge 3500
Better Photo
10-20-2010, 04:10 PM
Thanks for the help! The outside of the trailer is only 8 feet and the wheels are under that!
10-20-2010, 04:21 PM
So make it only 7.5' wide as you must be an expert at backing the thing up!
We're trying to be helpful...doesn't look like it's worth the effort!
Dave
10-20-2010, 04:38 PM
Numbers, I like others that have responded to your question fail to see the reason for knowing exactly the axle width if you already know your trailer is 8'. If you have the yard space why not make the pad 8'6" or 9' wide that way you may have an easier time putting the TT on it. Plus it will give you a solid area to walk around the TT.
PS. If what you are trying to do is build two separate thin concrete pads for just the wheels to sit on then we all missed the question.
10-20-2010, 04:44 PM
Not getting touchy, just looking for the correct info. I do appreciate your time and effort! Im not an expert at backing up, but have the proper location for trailer to be placed with ease. Sorry for the trouble and missunderstanding. Have a good day!!
10-20-2010, 04:45 PM
YES JUST 2 PADS i JUST GOT THE INFO I NEEDED IT IS 7'2" CENTER TO CENTER ON THE WHEELS!
10-20-2010, 05:33 PM
woot! now you just need to know how far from front to back as to where the wheels sit.
10-20-2010, 06:20 PM
Guess I am being touchy - please let us know how your pads work out.
10-21-2010, 09:54 AM
Thanks everyone for there help. I didn't mean to upset any one on the previous post's. All i was attempting to do was get a parking pad made before my rv arived in a few days. I have an area that is very easy to back into and wanted to make 2 pads 2'x5' to park the trailer on so when not in use the tires would not be in the dirt! Unfortunately i am not as welthy as some and cant afford to pour a 10x 30 slab to park on, so i chose to do the pads. All my fault!!! I didn't present the question proper to inform the reader on what was happining. Thanks again! Have a great day! Glad to be a new member!
10-21-2010, 03:59 PM
Rather than pour slabs, with the price of concrete these days, you might want to look into 16x16 concrete "stepping stones" at the home store. They are about 5 bucks each and you can back the camper where you want it; pull forward 16 inches or so; slide the concrete blocks under the wheels and back up onto them. You could also make a "slab" out of them by using a substrate of "rock fines" and set the stones on the substrate. Buy a sack of "resin sand"; sweep it into the cracks; spray with water; and when it sets the seams will be "weed proof" but still "temporary."
Slabs here need permits, but the above solution is "temporary" and no permit or approval is required.
10-21-2010, 04:49 PM
THANKS, i LIVE IN THE COUNTRY AND DONT HAVE ALL THOES REGULATION TO DEAL WITH , I ALSO HAVE SANDY LOAM SOIL AND IVE TRIED THE PADS LIKE THAT AND THEY WANT TO SETTLE AFTER A FEW PASSES OF THE WHEELS. I HAVE JUST LAID THE CONCRETE THIS MORNING AND LOOKS GOOD! READY FOR DELIVERY!!!!! THANKS AGAIN!!
