Old 04-21-2011, 11:27 AM   #11
jimh's Avatar
i can give u a suggestion if ur wanting to pull another wire but i would give it a lot of thought before u actually follow my advice.
if u can find the other end from the antenna end. i would tape a new coax (with a 6" overlap) then pull it thru. tape the entire overlap and tape each side of the overlap (to keep it from hanging up if pulled from either direction).
when i built my house, i put a couduit under the slab and would pull two wires, use one and the other was to pull additional cables.
again, before u follow this, give it a lot of thought. i don't know how they routed the wire or what u can hang up on.
pulling a wire would be after i tracked down the connectors and found those to be good.
if it is in a slide out, there may be a connection below somewhere. u know they didn't come thru the top.
jimh is offline   Reply With Quote
Old 04-21-2011, 11:38 AM   #12
Big-Dog's Avatar
The TV is not in the slide out. I'm thinking that the color change is where the wire comes from the antenna and goes through the roof for just a short distance. I will get into it maybe this weekend if it doesn't rain. I will port if I find the problem.
Big-Dog is offline   Reply With Quote
Old 04-21-2011, 12:11 PM   #13
jimh's Avatar
ok.
Sense my second tv is just under the ant (amp by tv1), i've thought abt switching my ant to the second tv wire and switching them at the amp. then switch tv2 to the old ant wire and see if tv one works ok off the amp. secondly see if tv 2 develops same intermittent problems.
if all worked, would leave it alone. if problem persisted as origional, i would suspect the ant or the amp.
all of that is way down the list.
Old 04-21-2011, 12:55 PM   #14
DAISY BOYKIN's Avatar
Second tv connection ??
Do you have a second TV connection, maybe in the bedroom, in a outside storage compartment for viewing a TV outside. If you do, there is a TV splitter for the second TV. this may be your problem and the reason for two colors of antenna wire.
You may have to work through a ceiling light or speaker hole for the new coax.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-21-2011, 01:12 PM   #15
Herk7769's Avatar
Ok, I just went out and checked.
In my camper (yours may differ):
The orange coax is the cable feed (middle) from the outside.
The Gray coax is the Roof feed (Looking from back - right connector).
The Dark Brown coax the Satellite feed from outside and goes to the top connector on the wall plate.
The Tan coax is the TV2 output (looking from back - left connector)
--- Mine goes to a splitter - one to the L/R and the other the Bedroom.
The front bottom coax is the TV1 output.
--- Not used in my camper for "neatness"
HAM CALLSIGN - KC3FFW
Old 04-21-2011, 01:19 PM   #16
Big-Dog's Avatar
Sounds good Lou, I will check this out tonight. Looking @ the attachment I think you may be on to something. Thanks for going to all the trouble of looking @ yours. This is a GREAT site for help from people like yourself.
Old 04-21-2011, 02:16 PM   #17
I have a sandpiper fiver and accidentally found a splitter when I pulled my front, bedroom, roof vent down to install a XM radio antenna. It had a crack on the input side and when I pulled it out to get to it the input side broke off. May be similar since both are made by the same manufacturer.
2011 F350 Lariat Ultimate Dually 6.7 w/ B&W Companion
2014 Heritage Glen 356QBQ
2016 Explorer Platinum, 1998 Mustang
1SG(Ret) (1987) US Army Aviation
Days/Nights Camped 2016: 34
dogwood36322 is offline   Reply With Quote
Old 04-21-2011, 04:26 PM   #18
skeeterbait8's Avatar
After reading about maybe the cable might be bad I had the hubby go up and we hooked a brand new coax and well...... that was a bust too. Still nothing. Looks like I will for sure be taking my Sat dish with me if I want to watch any TV.
Official member of the "Roo Kroo"!
2009 - 4, 2010 - 135
2011 - 95 and counting
skeeterbait8 is offline   Reply With Quote
Old 04-21-2011, 04:29 PM   #19
Herk7769's Avatar
A thumbs up "Thank you" would be great. You would be my first!
Old 04-21-2011, 05:51 PM   #20
jimh's Avatar
if u hooked the new cable to the input of the inside unit and got nothing, sounds like the ant or inside unit may be bad.
i've never been into one but i'm assuming that amplifier is in the ant and is powered via the coax. if that is the case, the unit inside and bat wing have to be connected to each other to work.
antenna
