Old 04-22-2011, 09:19 AM   #31
Herk7769's Avatar
I think it would be a LOT easier to swap the wall plates IMO.
HAM CALLSIGN - KC3FFW
Old 04-22-2011, 09:48 AM   #32
jimh's Avatar
A lot better. Usually Murphy is hanging around when I tackle a project.
jimh is offline   Reply With Quote
Old 04-22-2011, 09:56 AM   #33
Herk7769's Avatar
I have found that Murphy was an optimist.
Old 04-25-2011, 01:20 PM   #34
Big-Dog's Avatar
Checked out the antenna over the weekend with the amplifier from my pick-up camper and still no signal so I just order a new Winegard SensarPro from Camping World. I will report back as soon as I get it installed. I hope I get it before the weekend because I have to leave for Alaska on Sunday for 2 weeks work for NASA. But the good part is that when I get back and get my expense report done then I will be retiring for the last time. Life is GOOD
Big-Dog is offline   Reply With Quote
Old 04-25-2011, 03:30 PM   #35
jimh's Avatar
how many times have u retired for good....
abt murphy, i believe its his evil twin brother that follows me. has a cloud over his head....
i was looking under my slide and saw a large white, large black, and a large orange (i thought the orange was a faded red) wire ...couldn't figure what such large wires were doing going into the slide. then i remembered the post abt ant wires...live and learn.
Old 04-26-2011, 06:17 AM   #36
Big-Dog's Avatar
I guess that this will be the third time. Now is the time to enjoy life with some of the toys. Life is GOOD so don't pass it by. This is a good learning site if you read all the write ins. I know I have learned a lot just from reading. Thanks to all that have wrote in.
Old 04-27-2011, 09:49 PM   #37
Dodge Guy's Avatar
Check to make sure the copper wire in the middle of the coax is long enough to make contact with the socket in the outlet. on our Cherokee they cut the wire to short and I couldn`t get a signal from the cable side of the connection, my ant. side was OK.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 04-29-2011, 06:10 AM   #38
Big-Dog's Avatar
Well here is a up-date. I ordered a new Sensar Pro RFL-342 amplifier and hooked it up last night, still on signal on the meter. I unhooked it and ran the TV cable straight to the antenna with no amplifier and I can pick up 2 local stations. I guess the only thing left to do now is replace the BAT WING and the roof.
Old 04-29-2011, 06:33 AM   #39
Herk7769's Avatar
I can assume that the numbers and such were lit up on the new amp and the selector was on antenna when you read no signal strength.
Are you sure the white part of the roof antenna is pointed DIRECTLY at the antenna farm in your area. 10 degrees off and you will not get digital VHF stations. Digital UHF stations are only good for about 10 miles without the Wingman clip-on elements (then 30 miles).
I am concerned that you get 2 stations when direct wired to the TV from the antenna head, but not when using the amp in the middle. That does not sound "right" to me. When using the wall plate amp, have you tried running a long coax between the antenna head and the wall amp; then a new coax from the wall amp to your TV; thus bypassing the wiring in the camper completely?
Old 04-29-2011, 07:10 AM   #40
Big-Dog's Avatar
Yes I had the lights on Antenna/scan with 0 signal on the meter. I had the antenna on the station before with a signal before hooking up the meter. I will try the long wire from the antenna straight to the meter and another one to the TV when I get home this afternoon and will report tonight on the home computer. Thanks again Lou
antenna
