09-16-2011, 09:00 AM
Balance your tires!
I just had four new tires installed at Discount tire and wow they took some weights, about 3-4oz a couple and just like 1oz on the other two.
Should be in a for a smooth tow to the campground, heading our in about 2 hours.
09-16-2011, 09:05 AM
here is a pic of one
09-16-2011, 12:07 PM
I'd wonder about the correctness of the tire balancing if it's a discount tire store. To properly balance trailer tires requires a special adapter for the balancing machine. The center hub on a car rim is perfectly centered and easily balance on a standard machine. Trailer rims do not necessarily have a centered hub hole, and require and adapter so that the rim is bolted to the machine using the lug holes so the rim is centered. It maybe that your rims was not centered on the machine properly and thus the heavy weights.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
09-16-2011, 12:35 PM
balancing tires
I think that's a good idea to balance your TT tires, if you need to balance passenger car tires, why not trailer tires. How could they balance trailer tires if the rim was not centered, you would think that it's not rocket science and the person doing the job would notice, go with a reputable shop and that shouldn't be a problem.
Dennis
Dennis and Cheryl
2006 Ford F150 SC
2011 Tracer 2910BHS
F'ton N.B. Canada
09-16-2011, 12:45 PM
The lug nut are centered on rims but some of the rims do not have centered hubs that are 100% centered, thus a center balance trl rim will be unbalanced if balanced on a standard hub centering machine.
F.R.O.G. member
09-16-2011, 09:28 PM
I recently had 4 new tires put on my 5'r at NTB.
They claim they never balance trailer tires.
I asked them nicely to balance mine.
Another thing to keep in mind is If you are running LT tires on your camper.
Make sure they replace your valve stems with high pressure valve stems.
NTB (Alvin tx) used regular passenger car VS's on my 5'r tires, and they put one on my truck.
I made it back to Florida, but one failed yesterday and my rear tire went flat. Luckily I have a dually and the tire was not damaged.
Now I'm going to have to pull the 5'r to a local NTB to have all the VS's replaced ....
The high pressure valve stems will have metal in the center (between the cap and wheel) regular ones will not hold 80 psi. According to the local Tire Plus.
2003 cedar Creek 36 RLTS
Pushing an F350 diesel
Trailair
US Navy Persian Gulf Vet 1991-1994
09-16-2011, 09:39 PM
I had mine bead-balanced, so eliminated those ugly lead weights. And as my camper has aluminum wheels, it also eliminated the corrosion the weights cause. Plus they will never go out-of-balance, as the beads constantly adjust if the wheels get a bit of mud on them or the tires wear.
And I agree with putting the metal valve stems on. As I added stem-mounted pressure monitors, I had to use metal stems. But always better to spend a few extra dollars for the added safety.
09-16-2011, 11:34 PM
If what you mean by bead balancing is a hollow ring filled with lead beads put on the circumference of the wheel rim then this idea came out in the early 1950's, lasted less than 10 years and was discontinued as unreliable and ruined many tires on vehicles. I had not heard this term for years, till now. The tire companies voided all warranty on bead balanced tires. Perhaps with time and engineering the product has been improved. I don't know. Perhaps you could tell us (or me, if I am the only one) about how the bead balancing works.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
09-17-2011, 01:47 AM
Location: Canandaigua,New York (The heart of the Finger Lakes)
They actually put beads into the inside of the tires, its a packet that they rip open and pore into the tire itself ,then pop the tire on the rim.
David & Annamarie & 2-Pugs (Fatty and Harley)
2011 Rockwood Windjammer 3065
2011 Ford F-250 6.2- V8
2011 Hensley Arrow "NO-SWAY" Hitch
09-17-2011, 07:37 AM
Interesting, never heard of that. I've got to think about that one for awhile, lol.
09-17-2011, 08:03 AM
Balancing tire on what ever their on is a good idea. Unless it's a slow speed tractor or loader but most of the new equipments go's down the road pretty fast now a days. Why let it bounce or vibrate going down the road things aren't cheap any more .
09-17-2011, 08:36 AM
Yes, bead-balancing is a bag of loose beads rolling around inside the tire, and if I remember correctly, they are glass beads. Our local school division uses it on all of their buses, as do many long-haul truckers.
I especially like the fact that the beads adjust for any out-of-balance issue, and will last the life of any camper tire. If you get mud inside the rim, or even a stone in the tire, the beads will move around to compensate.
I have seen too many aluminum rims corroded and ruined by lead weights, so it is great to have an option.
09-17-2011, 10:42 AM
They do work, and we install them mostly in dually truck tires or larger mud grips. Most of them have what is called a drop-in bag, which you just drop the entire pack/bag inside the tire as you are installing it on the rim. Once the tire starts rolling, centrifugal force tears the bag open, letting the beads do their job.
If you have the right equipment, you can install some of these products thru the valve stem, without dismounting the tire........if you don't have a tpms attached.
There are a few caveats though with bead balancing. You want to make sure that any air you use to inflate (or use to top off later) is dry, with no moisture in it. If you have water in the air, or EVER use a fix a flat product, then the beads will clump up/together and not be able to work. Most of your tire shops are going to have a drier on their air compressor/lines, but the self serve pumps may not.
Also, if you have the tire repaired, make sure to use a patch on the inside, and have the tire shop place some baby powder over any excess glue they used when patching it.......or the beads can stick to that point. The baby powder will absorb the glue and allow the beads to roll over it.
Don't use a outside inserted plug, into the tire, as the beads can stick to it, and it impedes their rolling path.
Here is a link to the two brands we use:
=- Welcome to Tech International :: Leader in Tire Repair Products -=
Home
2011 Flagstaff 831 RLBSS
09-17-2011, 12:37 PM
Hey Bobby (wmtire), have you ever heard of this potential problem with balancing trailer tires ???
09-17-2011, 11:20 PM
I've never heard of an issue like this, has anyone else? I'm not saying you are wrong, but I used to mount tires at Sam's Club, and we didn't have a device like you describe, but did have pretty state of the art balancer.
FWIW, I would think that for any rim if the hub isn't centered then the wheel would not always fit. If the center is off then I would think the wheel may also roll down the road funny or kind of lopsided if that makes sense to you all!
09-18-2011, 04:35 AM
What Lindy is referring to is called a lug-centric adaptor. A lot of people who have a Toyota truck/SUV with aluminum wheels have probably encountered a need for this adaptor.....as Toyota wheels are notorious for not being able to balance properly without it.
A little explanation will be required. There are basically two kinds of wheels. You can have a hub-centric or lug-centric....and the name kinda tells it. A hub-centric wheel is centered off of the hub..............and a lug-centric (sometimes called stud-centric) is centered off of the studs/lug nuts.
You can usually just look at the lug nuts for a particular wheel and know if it is hub-centric or lug centric. Lug nuts that have flat surfaces are for hub-centric wheels. All the lug nut need do is to hold the wheel/tire assembly directly onto the hub. The reason there are hub-centric wheels is that it supposedly takes the stress off of the studs somewhat and requires less clamp force. You see a lot of hub-centric wheels on semi's.......and on the newer Ford pickup/SUV's since 1997. A lot of your older mag wheels, that had the lug nuts that you had to put a washer onto the shank of the lug nut, were also kinda examples of hub-centric wheels. Here are some pics for examples:
Now to lug-centric wheels. The vast majority of wheels are lug-centric...or are centered onto the vehicle/trailer spindle by the lug nuts. Most of us are used to seeing the conical or acorn type lug nut for these wheels.
The taper on the lug nut, fits into the matching inset of the wheel.....thus the wheel is centered and clamped onto the hub assembly using the lug nuts.
Now about balancing. Since most wheels are of the lug-centric (centered on the studs), then common sense would say they need to be balanced, using the same method (centered on studs)........right?
Since time is money (especially in the manufacturing process of vehicles), having to mount each wheel onto some kind of special lug centric adaptor just to balance it, doesn't make good economical sense. It is extremely time consuming. That's why even lug-centric wheels usually are made with precision center holes, so they can be balanced by centering off the center hole. You could say the wheel is actually both.... a lug-centric for mounting on the vehicle and a hub-centric for mounting on the balancer.
Now there are a few exceptions, as noted at the beginning with Toyota. They make some hub-centric wheels that just don't fit a hub-centric balancer correctly because of the way the center caps attach to the wheels..........and you need a lug-centric adaptor. This adaptor mounts to the lug bolt holes on the wheel, then slides onto the hub-centric shaft of the balancer. This is what Lindy is referring to.
These adaptors aren't cheap.....as they have to be very precision made since they are for balancing. The last one I had cost about a thousand dollars. You used to have to buy them for the specific bolt hole pattern you wanted, but they are making some universal ones now that will fit more of a variety of patterns.....but you still need a couple to fit the most common patterns. You also have to factor in the fact that your employees may lose them or some of the parts........and you can understand why many tire stores don't have them. It is also extremely time consuming to have to mount the adaptor to each wheel, to place on the balancer, then unbolt it all and go to the next wheel.
Now, IF and I really mean 'IF' the center hole of a lug-centric wheel is not made correct in the manufacturing process, then to properly balance it, you will need to use some kind of lug-centric balancer adaptor, since you can't accurately use it as a hub-centric wheel on a hub-centric balancer. You are not going to encounter this a whole lot, but you could.
It wouldn't hurt a thing to balance all wheels using a lug-centric adaptor......but it's not always necessary. If the wheel is made with a precision center hole, then it can be balanced hub-centrically. This saves the customer in time and cost.
As far as a wheel running lopsided, if the center hole is off center, then that wouldn't be affected with lug-centric wheels. Since you are actually centering the wheel off of the lug nuts/studs...then anything within the diameter of the bolt pattern would be a non-factor. The only way the wheel would be lopsided is if the lug/bolts are non-centered.
However it would jump all over the place if you tried to place it on a hub-centered balancer using an off-center center hole wheel.
I hope I have not clouded the issue with my long-winded post.
09-18-2011, 06:22 AM
Wow Bobby.....great post. Thanks for the explanation !!
09-18-2011, 12:09 PM
You really cleared that up! Thanks for the education. It makes sense that I'd never seen that type of wheel at Sam's I may have been working before their arrival, or since we mainly did cars & light trucks they never appeared.
Thanks for showing us all how to tell if we got them on our campers I can say I don't!
09-18-2011, 03:26 PM
Great post, wmtire.
My son works at Discount Tire. He said they balance trailer tires all the time and have never had a problem.
