10-28-2011, 09:27 PM
Bathroom door
Arrived at CG and bathroom door won't latch closed. The little door thing that goes in door frame hole seems to have moved bout 1/4" up. How do I fix this? Or do I put on list for warranty work this is our 1 at real trip interstate and everything ! Lol
10-28-2011, 09:40 PM
Many times this will happen if you are not perfectly level.
2012 Surveyor SP280
2005 Nissan Titan
10-28-2011, 09:41 PM
First, check to see if you have leveled the tt properly. If the tt is twisted it could keep the door shutting.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
2012 Nights Camped - 5
10-28-2011, 09:49 PM
Can I just pull up stabilizers and pull up onto level pads to raise slide side bout 1"
Or do I need to bring slides in
10-28-2011, 09:50 PM
That should be okay. Just check to make sure nothing is in the way of the slides.
Before you do that, raise the stabilizers and check the door. You may have the front or rear raised too high with the stabilizers.
Gary & Trish
10-29-2011, 10:22 AM
Lottery Non-Winner
Just as a TTP, I never move with slides out. Not even a little.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
10-29-2011, 10:31 AM
On second thought......
I have seen it done without any problems, but I've never done it myself. Since all it takes is a simple push of a button to run in the slides, why run the risk?
I think I have to agree with Ovair on this.
Gary & Trish
10-29-2011, 11:01 AM
too fast turbo sled
A good tip I learned years ago ....... shut all doors when travelling
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (2)
10-29-2011, 11:10 AM
I helped a friend back his trailer into his camping spot. Once we got it in where he was happy I asked him if we should level it as it was noticably higher on 1 side. His response was "thats what the leveling jack are for". When he was done the side door was rubbing on the frame and was binding when he tried to open and close the door. It looked like to me that in the process of leveling the trailer that he had twisted the frame. This was a brand new StarCraft trailer about 26 feet long.
I would do what was already mentioned earlier, raise the jacks and then check the door for alignment. Then lower jacks again paying attention to the bathroom door. It is possible that things may have move abit and the door plate may have to be readjusted. I also would not move the trailer with the slides out, even for a few feet. It takes less than a minute to move them in.
Todd & Sheila and kids
Rouleau, Saskatchewan
2012 Surveyor SV-305
Dads 2011 GMC 2500 HD
My 1999 Dodge Ram 1500 4X4
10-29-2011, 01:37 PM
I would not move it with the slide out like stated above - once the slide moves out of aligment - it will not be a good thing
check to see if the screws for the door hinge came loose - this will also cause the door to come out of aligment as well
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 268 |
| 18 members and 250 guests |
| BigDogD, dangerranger363, DSN46, elkhntr4evr, fonzie, h20ski, ladyff1481, Leathergypsy, mrthumper24, Namchief, navypoppop, nrcamp, RvBill3, stevo, Unruly, Vernk, wolfpack21643, wtrider |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
