Old 08-24-2011, 10:10 PM   #1
papap's Avatar
Batteries
When the panel shows my batteries are down to 1/4 or 1/3. do not remember right now, it is down to the last green light. I checked the batteries and they still had 12.2 volts. Is this about right????
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-25-2011, 06:50 AM   #2
Dave T's Avatar
This chart may help but I believe it's with no load or charge on the batteries for a few hours.
State of Charge 12 Volt battery Volts per Cell
100% 12.7 2.12
90% 12.5 2.08
80% 12.42 2.07
70% 12.32 2.05
60% 12.20 2.03
50% 12.06 2.01
40% 11.9 1.98
30% 11.75 1.96
20% 11.58 1.93
10% 11.31 1.89
0 10.5 1.75
Dave T is offline   Reply With Quote
Old 08-25-2011, 07:00 AM   #3
KyDan's Avatar
See post #9 in this thread--
http://www.forestriverforums.com/for...bie-15512.html
There is some descrepancy on the web as well. The problem is that only 1 tenth of a
volt makes a difference in charge state on a lead acid battery.
Basically a battery with no load and 12.75 volts is 100%
and a battery with 12.00 is down to 40%.
For maximum battery life it's best to keep your battey(s) charged to above 50%.
They will last longer if you charge them back up any time they drop to 1/2 charge.
Having said all that, I listen to my water pump and watch the lights.
IF a light dims significantly when the water pump cycles it's time for a charge.
If the water pump sounds tired near the end of a pump cycle it's time for
a charge. (Water pump slows down as pressure builds and get's noticeably slower
just before it shuts off.)
This is not scientific at all but seems to work for me.
Also these panel indicators are NOT very accurate but when mine gets down to
1 led when I push the button I'm getting very low on charge.
One thing I do that I really think helps coax long life out of my batteries is
I have a battery tender Jr. on my trailer at home.
These little chargers are fully automatic and will boost the battery voltage
enough to cause bubbling in the electrolyte. This keeps it mixed up and cuts way
down on sulfide build up.
I have a battery tender Jr on my truck in the garage because the electric brake controller
is a drain even with the key off. I have one on my trailer as I said.
My truck still has the original factory battery. It's a 2004.
My trailer is an 08 and just this June we camped without hookups for 5 nights and
used our MaxxAir fan every night and watched national news on TV every evening
using a little cigarette socket plug in inverter. We also watched one DVD movie.
We were careful on lighting. We have a couple LED lights that we use for moving
around inside. We have a fluorescent thin lite over the table for eating and reading.
My water pump still sounded peppy on our last day and my LED battery indicator
still had 2 lights on when we pushed the button.
I have only 2 12v regular old "crank/deep cycle" marine batteries.
Nothing exotic.
I'm not an employee or anything but these guys have the best price on the
internet for a battery tender Jr.
It's $20 with free shipping. If your trailer is parked where you can reach 120v for
a battery tender Jr. I highly recommend using one.
Battery Tender Junior
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 08-25-2011, 08:27 AM   #4
papap's Avatar
charge
My motorhome has dual batteries. I can turn the discontect switch off and after about 3 days the voltage is down to around 12 volts. I have them charging now. When I get home tonight. I plan to discontect one of the wires and see if there really is something drawing them down or if they are bad.
Old 08-25-2011, 08:33 AM   #5
Herk7769's Avatar
As you can see from the attached info:
THIS IS THE RANGE REQUIRED TO TURN "ON" THE APPROPRIATE LED
CHARGE LIGHT 12.70 TO 12.85 VOLTS
GOOD LIGHT 12.10 TO 12.15
FAIR LIGHT11.60 TO 11.65
LOW LIGHT 6.00 VOLTS OR MORE
VALUES IN D.C. VOLTS Ī 5%
no lights = dead battery
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 18 views)
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 14 views)
HAM CALLSIGN - KC3FFW
Old 08-25-2011, 12:41 PM   #6
Triguy's Avatar
I've been using this device until I can decide if I want to install a more permanent solution in the trailer. I'll plug it into the power receptacle in the trailer when it want to check.
It "seems" accurate enough. I notice that it measure about 0.04 volts higher than my multimeter. I haven't actually compared it to the lights on the monitor panel on the wall. Maybe this weekend.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-25-2011, 01:05 PM   #7
papap's Avatar
Herk. Looks like if those numbers are correct. My display lights are way off. I think I will do like the post above and find a better way of testing batteries.
battery
