Old 06-01-2016, 12:24 PM   #1
Camp Bartender
Battery Shot already?
My Battery is a year old and It wont hold a charge anymore, I have to plug it into shore power or to the truck even to get the tongue jack to raise or lower the tongue....Shouldn't they last more than a year?
2013 Dodge Ram 1500 Express, 5.7L HEMI
2015 Forest River Wildwood 28DBUD
2015: 7 Trips, 20 Nights Camped
2016: 7 Trips, 23 Nights Camped
2017: 5 Trips planned (so far)
stevensmith2859 is offline   Reply With Quote
Old 06-01-2016, 12:45 PM   #2
Did you leave it connected all winter? How was it stored? Did you put it on a maintainer while on storage?
If you left it connected it would certainly be dead by now and if it is completely discharged now it could have been damaged. If it was left out in the cold and uncharged and unmaintained further damage may have occurred. If it is dead it would need a condition charge and then use a volt meter to test it.
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-01-2016, 12:56 PM   #3
Camp Bartender
I left it in the camper all winter, my own fault. So its looking like I will need a new battery. Even after having it plugged into shore power, its wont hold a charge....It is what it is, my own fault.
Old 06-01-2016, 01:15 PM   #4
If you have a good external multi stage charger I would try that before scraping it. Maybe even buy one if you dont have one and use as a maintainer for next winter.
Old 06-01-2016, 01:31 PM   #5
Does it have electrolyte in it? If you haven't maintained it by adding distilled water as needed, it could be dead. Also, charging a battery with low electrolyte is a hydrogen bomb waiting to explode.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 06-01-2016, 01:34 PM   #6
shughey00's Avatar
It is nice to have a good battery charger..one that can recover deeply discharged batteries. The tricklecharger in the converter won't be able to recover them usually.
Probably the best $90.00 investment to have..a good smart charger with the different recovery rates and voltages. If the battery is deeply discharged it takes a higher voltage to reverse the sulfating in the battery.
Now if the battery was extremely discharged then sometimes nothing will reverse it BUT it is fairly new and usually the bad happens to older batteries where this happens over and over. Then the sulfate deposits on the plates is such a hard crust you just can't reverse the damage.
I fully recovered a deep cycle battery in my Lance camper when the dealer left the battery on for 2 months and drained it near dead. But it was a fairly new battery.
2004 Cedar Creek 34CTKS heavily customized
2006 Ford F350 FX4 Lariat Dually w/tow boss
1999 Lance 1110...cause it's easier for short trips.
shughey00 is offline   Reply With Quote
Old 06-01-2016, 03:13 PM   #7
Moderators' Assistant
bikendan's Avatar
You should never leave a trailer(with battery)stored without it being plugged into shore power or use a battery disconnect switch.
If you don't have one, you need to install one.
I left mine stored, without shore power, for 4 months.
Because I have a disconnect switch, the batteries were still nearly fully charged when I picked it up.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 06-01-2016, 08:28 PM   #8
While a good battery charger is a great idea, there's more to converters than most people know. I replaced the crummy WFCO converter with a Progressive Dynamics converter. It uses a 4 stage charger. It will pull a good 20 amps AC if the batteries are in need of a lot of charging.
Read here:
Best Converter Charger for an RV - Smart VS. Dumb
Old 06-20-2016, 10:15 AM   #9
Camp Bartender
I actually took it out of my camper this past weekend, it seriously had about zero water in it. Added some water and I'm going to put it on a charger to see if I can bring it back to life. My own fault for what its worth, but maybe its time for a battery disconnect switch....
Old 06-20-2016, 04:10 PM   #10
I go RV'ing not Camping
jgourlie's Avatar
If you get a battery tender/minder and stick it on the battery, it should revive it in a week or two.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
battery
