Old 05-19-2013, 01:40 PM   #1
campfirefun's Avatar
Bearings
Our rockwood has the grease zerks on the wheel bearings. When I added new grease today the old coming out looks not so great. Do I just keep pumping until the new is coming back out near the zerk. Seems like a lot will be needed. That's not a big deal as I would rather do it right than have to be towed on a trip
campfirefun is offline   Reply With Quote
Old 05-19-2013, 01:56 PM   #2
lswartz's Avatar
It does seem weird, but that method is in the instructions for my TT.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 05-19-2013, 01:56 PM   #3
I think that the seal is blown or leaking past if the grease is coming back out. The grease should only be added as needed, until resistance is felt. If you feel the need to replace the grease, you'll need to disassemble, clean and re-pack the bearings. Keeping pumping fresh grease in will not get all of the old grease out anyway. Randy
Old 05-19-2013, 02:03 PM   #4
I don't think the seal is broke as all four do it and have since first owning it
Old 05-19-2013, 02:14 PM   #5
Not if he has Dexter EZ-Lube bearings! That's exactly what he's supposed to be doing, and YES, keep pumping (slowly) until you see new grease.
Old 05-19-2013, 02:25 PM   #6
Twisty's Avatar
I jack up the axle/frame and have a helper slowly rotate the wheel as I pump the grease in.
It does take a lot.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
