Old 12-28-2015, 08:45 AM   #21
rfenters's Avatar
Our 2016 Salem Cruise Lite 261BHXL has done the exact same thing. Planning on a going to Ocean Lakes in Myrtle Beach SC for New Years in a few days. I was looking to see if anyone has had this problem also. I want to build something that would not take up too much storage for larger things under there.
rfenters is offline   Reply With Quote
Old 12-28-2015, 03:14 PM   #22
alykat1325's Avatar
I'm not sure of your model but LandJ had a better solution for keeping it slim than I did. I just used what I had available. Not sure how much time you have but you can also shore it up temporarily until you get back. I could hammer mine back in place before I fixed it. You could shore it up with some 2X's until you got back.
2007 Toyota Tundra
2016 Salem Cruise Lite 262BHXL
alykat1325 is offline   Reply With Quote
Old 12-28-2015, 04:35 PM   #23
rfenters's Avatar
That's what I'm thinking. Thats weird though how many of them have done it. Did your screws break or did the wood split?
Old 12-29-2015, 11:04 AM   #24
alykat1325's Avatar
The wood split some on mine but there was not one screw found. It probably would have held up if there were more screws. One thing to note when you do go for the permanent fix, make sure the plywood on top is straight or flat on top when you get done. When I did mine I measured both sides and built to that measurement. It turned out to be the wrong thing to do because it put a hump in the bed that you really couldn't notice until you slept on it. Needless to say I had to redo mine to what was there. Hope you get to enjoy it this weekend. Safe travels!!
2007 Toyota Tundra
bed, salem
