08-26-2015, 10:44 PM
Bent axle?!??!!?
Anyone see this?? I had a tire fail and was removing them to replace with new ones. Of course I jacked up the trailer on the frame and never the axle. The funny thing is now I have rub marks on the inside edge of the TT on the left side wheel well area. The axle seems to be bent in the upward position and should cause the top of the wheel to bow outboard??? I always try to make sure we are not overweight, (the TT anyways!!). Any thoughts?? What about the axle bend?? Think it is safe to tow??
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2016 SILVERADO 2500HD 6.6 Duramax
2012 280BH Casscade
08-26-2015, 10:45 PM
other pics
Here are the other pics
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2012 280BH Casscade
08-26-2015, 10:49 PM
ive seen other trailers with a bend. ill have to check mine. as for the rub marks id check to see if you axle isnt centered properly on your leaf springs
2015 Cedar Creek Silverback 33IK
08-26-2015, 10:51 PM
your axle should have a bend up ward or "camber" my understanding is that when you load the trailer that helps take the weight. I had a Komfort TT that the tires were wearing funny on the inside,took it to Les Schwab and they said the axles lost the camber. When i looked at the old axles compared to the new ones it was very obvious, old ones were flat across and the new had quite a bit of camber in them.
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
08-26-2015, 10:57 PM
Given that the axle has an upward bend shouldn't that put the top of the tyre further away from the frame where it is rubbing rather than closer?
My axles have an upward bend also but they seem to straighten with load in the tyres.
08-26-2015, 10:58 PM
Also i am wondering if the replacement wheel has a different off set and that is why it is now rubbing, unless it is the same wheel then i dont know. doubt that the axle has shifted as the springs are bolted to the mounts welded to the frame....
Mike, Lisa and Jake
Commercial Member
If you want to file a complaint about defective axles you will need to be able to provide actual measured axle loading to confirm you are not overloaded.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
08-26-2015, 10:59 PM
If there is no clearance on the opposing side as well I think your wheel offset is incorrect.
08-26-2015, 11:14 PM
Appears to be normal to me. I have several different types of trailers. Every trailer axle I own is shaped like the one in your pictures.
Carry on....
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
08-26-2015, 11:31 PM
Who Dares, Wins
From my axle flip thread..
Not normal but what it is.. And yes the axle is supposed to have an natural upward bend in it.
EDIT: Rubbing on ours is caused by any severe off camber situation.
2015 Chevy HD D-Max
2022 Impression 315MB
08-27-2015, 12:21 AM
Is that on the same side that you had the failed tire on?
If so maybe the flat tire caused a redistribution of weight and you got the rub.
I would also think as mentioned before that the bend in your axle would make the tire flare out not in.
My axles are square tube but have a dimple in the middle for camber.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
08-27-2015, 04:22 AM
Are any of the other tires hitting the body? something is loose, bent, broken, etc for that to happen. see if that happens when turning, right or left, get under and look to see whats happening.
08-27-2015, 05:06 AM
Might check the triangle piece cannot think of the name for it. It where the two leaf springs are attached to in the third pic.
Just helped a person. One broke just before getting to CG. We took the other one off. The bolt hole that goes to the frame was slotted (wore) over two inches. It was cause the other to fail. Try to get a pic if he still has the parts. Did it last month.
08-27-2015, 05:10 AM
Could not see the wear as it was inside the mounting bracket. If trailer was blocked up and then could raise and lower the axles. His is a 90's model. I told I would replace the bolts and shackles and repack bearings for the piece of mind and that's when he found the other bad shackle.
08-27-2015, 06:12 AM
Who Dares, Wins
Equalizer is its name
2015 Chevy HD D-Max
08-27-2015, 06:49 AM
Boss Ox & Drovergirl
We've had this happen on our 18 ft Ponderosa Stock Trailer and had to have the axle replaced. It wore out 2 tires before I realized the axle was the culprit. I believe in my case, it was running over / rubbing against some curb like a fuel island or curb on a too tight turn.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
08-27-2015, 10:49 AM
Your axle looks normal. Axles come pre-loaded with a certain amount of camber built in and they arch upwards. And, as was mentioned it helps them (under loading) to remain straight.
You really didn't define which side the tire failed? If the tire failed on the right side, it could have left the axle drop enough (on the right side) that it created clearance issues between the tire and wheel-well on the left side and caused it to rub the left side. When the tire went flat it would have allowed the axle to drop on that side and angle down to the extent the clearance from the pre-set camber then wouldn't matter.
I would think once you get a new tire and have it mounted to the axle, all will be fine again as far as clearance issues. Only you can decide if the rubbing on the tire in the picture has done enough damage to be safe?
Now... if the tire that failed was on the left side AND the rubbing is on the left side, I suspect something is out of align. Possibly the rubbing caused the tire to fail?
08-27-2015, 10:54 AM
Or walking beam.
08-27-2015, 01:01 PM
Thanks for all of the input. Camber adjustment make compleate sence to me and I will forget about the slight bend for now. I have not changed the wheels and they are a zero offset rims. The rub marks on NOT on the side of the tire failure and the tire look to have the same clearance from side to side. Just one side rubbing. It could have just been a one time contact on a rought road.
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2012 280BH Casscade
08-27-2015, 01:10 PM
A jackknife situation (when backing into site on blacktop) could possibly make the tire come in contact with the inside.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
