Old 05-03-2016, 03:40 PM   #1
JudiVan n Gus
judivan's Avatar
best device or app for height information
I am looking for a way to give me height of bridges and overhangs? I have a trailer that is 13'2". Is there such an app or device that can help me with that and reroute me around the obstacle before I get to it? Please help me if you can.... Thanks for your help in advance.. Van
JudiVan
Gus = 5.5lb Maltipoo lap puppy
2006 F250 Turbo 6.0
2016 FR Heritage Glen
It's not where you go in life, it's who you have with you that matters
judivan is offline   Reply With Quote
Old 05-03-2016, 03:51 PM   #2
Not sure if they have an app, but the truckers almanac give clearance info for routes. There are also downloadable POI files for gps.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 05-03-2016, 03:59 PM   #3
clr
Their is a app for a GPS called lowclearance that you may be interested in. It will warn you of a low clearance within the distance that you chose. I have mine set at 2 miles. It will flash a warning symbol on your GPS screen where the low clearance, and sound an alarm. It will not auto reroute you around the low clearance.
If you want total type operation such as rerouting or not putting you on any route with a low clearance. Then you are looking a one of the RV or Trucking GPS units.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-03-2016, 04:11 PM   #4
What type of GPS system are you using?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 05-03-2016, 04:33 PM   #5
clr
I am using a Garmin nuvi 2555 currently with the lowclearance app installed and the proximity alerts turned on.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
Old 05-03-2016, 05:54 PM   #6
I use low clearances on Streets & trips. I find it to be fairly inclusive. I have a built in NAV so cannot use LC. Are you unhappy with it. Most probably the best if you don't want to go commercial.
Old 05-03-2016, 10:13 PM   #7
clr
I have been happy with low clearance and it has worked well for us. The only limitation I have found is that it went off on I74 near Morton Il and at first the alarm was going off and the GPS display was not showing where the low clearance was until I got closer. Then the warning was right on the interstate but I could see there was no overpass. The low clearance was right under the interstate one lesson learned.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
Old 05-03-2016, 10:30 PM   #8
FYI;
I got an e-mail last week that LC has a big update you can download. Until you find something else you might want to make sure you have the latest. You can download it off the membership page on their site.
Old 05-03-2016, 10:37 PM   #9
gectisme's Avatar
If you have a smart phone check out the CoPilot GPS App. You can enter in your height and it will route you around obstacles.
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 05-03-2016, 10:53 PM   #10
flymhi's Avatar
S&T is no longer supported or updated by Microsoft so the data is aging out.
The Allstays app has low bridges bridges noted. Check this thread
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
