Old 06-29-2019, 02:35 PM   #1
Best lube spray for slide out
I want to lubricate my slide mechanism. Ideas?
OburgOrange is offline   Reply With Quote
Old 06-29-2019, 02:41 PM   #2
D W
D W's Avatar
You didn't specify what type of slide you have, but if you have a Lippert In-Frame slide Lippert does not recommend lubrication, just to keep the tracks clean of debris. Some folks use a dry film lubricant to ward off rust. The gear packs are pre-lubed and sealed.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 06-29-2019, 02:42 PM   #3
What brand of dry film lubricant?
Old 06-29-2019, 03:12 PM   #4
bikendan's Avatar
There are a number of slideout-specific spray lubes. Even Wal-Mart has them or CW.
Equalizer WDH
Old 06-29-2019, 03:37 PM   #5
D W
D W's Avatar
This will do the trick:
https://www.lowes.com/pd/blaster-har...SABEgIr0PD_BwE
2016 Salem 27RKSS
Old 06-29-2019, 03:55 PM   #6
Brand name isn't as important as the fact it needs to be a DRY lube. Yes, all go on wet but if it stays oily/greasy it will pick up road dirt and things will end up worse than if nothing was sprayed on.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-30-2019, 04:49 PM   #7
On my schwintek slide I used the WD40 Dry lube with PTFE, couldn't find the CRC Lube they recommended.
Jim & Kathy
Bailey, waiting at the Rainbow Bridge
Gracie, a rescued Beagle
2007 Chevy Tahoe
2008 FR Surveyor 233T
JimChow is offline   Reply With Quote
Old 06-30-2019, 05:03 PM   #8
Jayhawker
Jayhawker's Avatar
This is the slide out DRY lube that we use.
2018 Surveyor 243RBS
Jayhawker is offline   Reply With Quote
slide, slide out
