I learned my lesson a long time ago in another hobby. I used to think that I could get buy with less expensive items that professed to do the same job.
I ended up with a shelf full of the less expensive items I never used and still ended up buying the item I had my eye on in the beginning but thought it was too expensive.
I now "buy once and cry once". I have a TST 507 and couldn't be happier.
One nice feature is that you can program the unit for several different trailers. If you have a coach, travel trailer, boat trailer, and utility trailer, all you need to do is purchase extra sensors for the extra trailers. They get programmed with a different designation number so when you change what you are towing you merely select the new number. No need to own several units.
Don't know if others do this but the TST unit will.
