Old 03-01-2015, 08:05 PM   #1
chrismbrock2009's Avatar
Bigfoot leveling not so level.
We have a 2014 3170ds and it seems that every time we use the Bigfoot system it's always leaning a tad to the right or left. I press "auto" when using the system.
Anyone have any input or suggestions?
2014 Sunseeker 3170ds
Global Wedding Photographer
chrismbrock2009 is offline   Reply With Quote
Old 03-01-2015, 08:06 PM   #2
Name:	ImageUploadedByForest River Forums1425258394.220960.jpg
Old 03-01-2015, 08:08 PM   #3
Name:	ImageUploadedByForest River Forums1425258507.035915.jpg
Old 03-01-2015, 08:13 PM   #4
Average Joe
MrJoe's Avatar
Looks like it needs to be calibrated. Looks like the left and right lights are on? I thought someone posted the instructions a while back. Have you searched for the manual?
I get better results by leveling using the manual mode. For me the auto mode just raises the coach higher than it needs to.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 03-01-2015, 08:16 PM   #5
Yes Left & Right lights are on.
No I did not read the manual. I should have before posting this but I assumed that it would just work correctly I will dig threw the manual books and read up
And yes its sky high, I agree with that as well. Never used the manual mode.
Old 03-01-2015, 08:19 PM   #6
Average Joe
MrJoe's Avatar
I found it... Look towards the back of the manual.
Joe and Karen
Old 03-01-2015, 08:52 PM   #7
Roger that
Old 03-01-2015, 10:13 PM   #8
Manual really doesn't say much about calibrating the unit or what to do if it's leaning from side to side.
Old 03-01-2015, 10:32 PM   #9
Average Joe
MrJoe's Avatar
Looks like page 17... Did the system ever work properly? I don't believe the Right and Left lights should be on with the center "Level" light. Seems like the system timed out and quit before it was finished. I'd find a fairly level spot and try it again. If it still messes up, try page 17.
Joe and Karen
Old 03-01-2015, 10:39 PM   #10
Will do. So if I read page 17 correctly it essentially says to go into program mode and manually level the unit. Then store that ?
Old 03-01-2015, 10:57 PM   #11
Average Joe
MrJoe's Avatar
That's how I see it. You're saving the "level" reference.
Joe and Karen
Old 03-03-2015, 10:18 AM   #12
Soooo. Attempted to manually level to reset auto mode. Back left foot doesn't seem to be working correctly. Gets down and pushing up the rear maybe a few inches then starts to squill and won't go any further. Right rear will jack up as far as I want without any problems. Any thoughts ?
Old 03-03-2015, 11:26 AM   #13
arpipeliner's Avatar
If squalling it could be at the max on extension.
arpipeliner is offline   Reply With Quote
Old 03-03-2015, 11:37 AM   #14
dan-nickie's Avatar
Are you on level surface?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-03-2015, 11:44 AM   #15
TURBS's Avatar
X2
Old 03-03-2015, 11:47 AM   #16
On my driveway which has a very slight and I mean slight incline.
No it's not fully extended. The right side will go higher than the left.
Old 03-03-2015, 01:13 PM   #17
Would have to measure the exposed ram and see what the max extension.
My guess is that they are close to the max. And that why the one isn't able to go down.
Other thing it have to be a different length cyclinder. Should be to look at it and see if not check the part numbers on the two. It's always possible in human error.
Old 03-03-2015, 07:50 PM   #18
Explorer
My parents had an auto level on their rig that never worked and it ended up being the left and right wiring was reversed. Lucky for them it was found under warranty.
For anbservation, your picture of the level is on a counter, you should be leveling to the bottom of the freezer. Now, I have found a location on my counter that mimics the freezer for ease.
But, the squeal sounds like an issue with hydraulics.
Best of Luck
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
leveling
