Old 06-23-2016, 01:50 PM   #1
Black Water Flush
Being a newbie to owning an travel trailer, is there a recommended process/time for using the black water flush?
TIA
Stu & Nina Stoner
2013 F-150 STX 5.0
Grey Wolf 22RR
Central PA
stustoner is offline   Reply With Quote
Old 06-23-2016, 02:03 PM   #2
chrisbailey13's Avatar
Wait until it is more than 1/2 full before flushing. use PLENTY of water during the flush if you can, after it is empty, fill it at least to the previous full point and drain it again. Make sure you put a gallon or so back when done so your poop won't stick to the bottom of the tank
2014 Georgetown XL 352QS
2013-2018 Days Camped-275
chrisbailey13 is offline   Reply With Quote
Old 06-23-2016, 02:47 PM   #3
Left Coast
iNVEST IN A CLEAR ELBOW......you'll be able to see the results....and stay there while using flush.......some have walked away and forgot it was on......not good! lol......when done flushing and valve closed, you can add a little water to tank using the flush......
water, black, black water
