Old 02-18-2011, 11:09 AM   #11
NorminN.B.'s Avatar
I will use cement blocks like Jollyman, except, I will use 2 blocks stacked side by side, like Stuff did, and sitting on a plastic footer. I got them from the dealer, when they delivered it. Thanks.
NorminN.B. is offline   Reply With Quote
Old 07-12-2011, 10:15 AM   #12
Villa Estate 392FLFB
The_Stuff's Avatar
When I moved my trailer back after the great flood scare this year, i only used 6 of the 8 blocks i made and it works good to.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 07-12-2011, 11:05 AM   #13
We have a 40 footer on a seasonal site also.
First level the trailer side to side by the tires. Then you can level it with the front trailer hitch. Then place blocks in at least 4 places on each side, and use a hard wood wedge to tighten the blocks to the trailer frame. you should be able to get some of these wedges from your local dealer. Double check the level at the various areas. We used a bottle jack to fine tune each area, and it worked out great.
I hope this helps
Kevin
Seasonal in Wi Dells, WI
2007, Salem 4022B
kev2504 is offline   Reply With Quote
Old 07-13-2011, 06:52 PM   #14
NorminN.B.'s Avatar
Finally got it blocked and leveled. Here is a picture
http://i53.photobucket.com/albums/g5...1-07-02002.jpg
http://i53.photobucket.com/albums/g5...1-07-02001.jpg
http://i53.photobucket.com/albums/g5...1-07-02004.jpg
Old 07-14-2011, 10:50 AM   #15
Looks good. I think I will double up on the block like you did. I only have single stacks.
Kevin
2007, Salem 4022B
Old 07-14-2011, 03:31 PM   #16
NorminN.B.'s Avatar
I think double makes it a little more secure. The dealer provided the plastic pads underneath the cement blocks.
