Old 02-10-2011, 02:15 PM   #1
NorminN.B.'s Avatar
Block and level park model
I was wondering if anyone had some instructions on how to block and level a 39' park model. It was delivered to my property, in Nov, got it stuck in the mud and I want to move it and level it in the spring, when it dries up. Not sure where to start, front or back. Thanks
NorminN.B. is offline   Reply With Quote
Old 02-16-2011, 10:50 AM   #2
NorminN.B.'s Avatar
Does anyone have any suggestions. Thanks
Old 02-16-2011, 12:35 PM   #3
Send a message via Skype™ to scubieman
What I would recommend is get a level. If it's on dirt make sure tires are on some kind of board to slow down sinking in the dirt over time cause of the weight of the trailer. I would then put boards under each weight load location. The more places that take the weight the less it should move. Hope this helps.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 02-17-2011, 09:44 AM   #4
NorminN.B.'s Avatar
Thanks, Scubie, would it be easier to start leveling in the rear or the front, or does it matter? NorminN.B.
Old 02-17-2011, 10:00 AM   #5
I would think side to side first.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 02-17-2011, 10:04 AM   #6
There is no correct answer you have to do it sync. If you don't you may go to far up on one support then you can not get another support to extend far enough do left that side to level.
Leveling can be a pain, just make sure in the end the camper is level and even weight on each support jack.
Old 02-17-2011, 06:49 PM   #7
Villa Estate 392FLFB
The_Stuff's Avatar
I made 2 foot high blocking out of 4x4's. I made 8 of them. 2 in the very back, 2 behind the wheels (where the bathroom is) 2 at the front right behind the hitch hookup, and the last 2 in front of the wheels.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 02-17-2011, 07:34 PM   #8
NorminN.B.'s Avatar
Thanks, Scubie. I will do the same as you, only I will use cement blocks, on a plastic pad underneath.
Old 02-17-2011, 07:53 PM   #9
The_Stuff's Avatar
thats what i wanted to do and do like 6 sets per side, but noone in town has them. thing of the past here apparently.
also jollymon has something like that.
https://picasaweb.google.com/NDJolly...erAtMapleLake#
Old 02-17-2011, 08:12 PM   #10
j2detroit's Avatar
we have our 30f cherokee at a seasonal site whe we moved it in first thing we did was get it as close as possible to leval from side to side wich wasnt tuff at all if you have a few different sizes of lumber we then levaled it front to back which can be done with the front jack i then lowred the screw jack down onto 6x6x2 planks of treated ceader then after checking to make sure everything was still nice and leval i then went underneith with 4 of those screw jackstands and somemore 6x6s i placed two directly infront of the axels and two directly behind the axels and the other two inbetween the front jacs and the front axels these were turned just enough to put pressure on the frame when all done i have also installed 4 screw into the ground tie downs like those used in moble home parks our camper is nice and solid and doesnt rock or move it is also a good prctice to dive down ther every so often and check things out espsallt check for any seiiling good luck
j2detroit is offline   Reply With Quote
