Old 09-18-2011, 12:20 PM   #1
blower not going on our 2010 sv-294 surveior
everthing is working except our blower only used our heat like 3 times what could the problem be
madenford is offline   Reply With Quote
Old 09-18-2011, 12:26 PM   #2
TURBS's Avatar
Fuse? Breaker?
Old 09-18-2011, 01:23 PM   #3
blower not working
no both are fine it clickes but the blower dont kick in
Old 09-18-2011, 01:31 PM   #4
sherdep's Avatar
did the blower ever work?
Is the blower in the A/C unit or is it the seperate blower for the furnace?
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 09-18-2011, 02:03 PM   #5
seperate like i said everything works ac gas to stove hot water heater when i try to turn on the heat i put it to furnace turn up the heat to like 80 and it clicks but nothing the blower wont kick in
Old 09-18-2011, 02:07 PM   #6
and yes it did it was working last week now nothing
Old 09-18-2011, 02:10 PM   #7
Old 09-18-2011, 06:35 PM   #8
rbarrieau's Avatar
relay
The time delay relay may be stuck open --pull the fuse for the furnace and it may re-set. Just a note the relay has it's own circuit on some units it may be linked to something else.
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
rbarrieau is offline   Reply With Quote
Old 09-20-2011, 04:46 PM   #9
sherdep's Avatar
you can also verify that the fan is getting voltage when turned on as a process of eliminating the fan being the issue or not.
