Forest River Forums
Sunline User Photos
Old 10-25-2011, 09:47 PM   #1
Blowing out water lines
where is the best place to hook up a air hose to blow out water lines to winterize.
2006 F250 psd CC Sb 4x4 with B&W companion.
2007 Wildcat 28rks 5'ver
2005 Harley Davidson
2009 Weimaraner "Dog"
"1"yro daughter"8" yro son A DW
onequicksportster is offline   Reply With Quote
Old 10-25-2011, 09:49 PM   #2
too fast turbo sled
f1100turbo's Avatar
your city water fill inlet !
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (2)
f1100turbo is offline   Reply With Quote
Old 10-25-2011, 09:50 PM   #3
too fast turbo sled
f1100turbo's Avatar
with this duma jiggy
Ron and Amy Benhart
Old 10-25-2011, 10:51 PM   #4
Thanks a million!!
Old 10-26-2011, 06:05 AM   #5
cfsoistman's Avatar
I made up an adapter with a gate valve that screws into the City Water connection and has a quick connect for the air hose. That way I can move throughout the RV and open and close faucets, toilets etc to allow the water to escape. I can also do other things while the low point drain is allowing water out. I used a flexible connector so it hangs at a 45 degree angle.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-28-2011, 10:05 AM   #6
tonyz's Avatar
That makes sense to blow it out at the city water intake, but how can you blow out the line from the holding tank to the pump? Will it back pressure through the water pump and clear the line to the holding tank?
tonyz is offline   Reply With Quote
Old 10-28-2011, 10:24 AM   #7
Moderator
acadianbob's Avatar
You can't blow out your holding tank. There should be a drain hose with a screw on plug at the bottom of your RV to drain it. Also, don't put any antifreeze (RV type) in your holding tank. Be careful how much air pressure you use when you blow out your lines. Check around but I believe you don't want to exceed 45 psi or so. But don't go in there with 100 psi or you could blow things to smitherines! Lots of people use pressure limiters on city water to avoid this problem.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
Old 10-28-2011, 10:27 AM   #8
Moderator
acadianbob's Avatar
I guess I didn't answer your question which was the line from the holding tank to the pump. You may have a valve near the pump that has a short hose for introducing RV antifreeze. After your holding tank is empty, open this valve and you may get enough "relief" in the line to allow any water in that line to flow back into the holding tank. I also use RV antifreeze to make absolutely sure that every drop of water is out of the pump. It doesn't take much water to ruin that pump; a few drops may be enough . . .
Old 10-28-2011, 10:35 AM   #9
Rugged Brown's Avatar
Attachment 8801
I thought that was a thingamajig.
Terry/Bernadette
Lily the Yorkie
2010 RAM
2011 Flagstaff 8528 CKWS
Rugged Brown is offline   Reply With Quote
Old 10-28-2011, 11:01 AM   #10
too fast turbo sled
f1100turbo's Avatar
Its closely related to the muffler belt that I've seen some replace when in fact the blinker fluid was just low. Common mistake among rookies.
Ron and Amy Benhart
» Online Users: 269
18 members and 251 guests
BigDogD, dangerranger363, darkcloud, DSN46, elkhntr4evr, fonzie, h20ski, ladyff1481, Leathergypsy, mrthumper24, Namchief, navypoppop, nrcamp, RvBill3, Unruly, Vernk, wolfpack21643, wtrider
Most users ever online was 944, 03-04-2012 at 01:27 PM.
Close [X]
