Blue Ridge 3025 water tank drain
I have a very strange question. While attempting to winterize our new 5th wheel for the winter I don't know if I have found the fresh water tank drain. I located blue and red pex lines on the outside of the frame near the middle hydraulic jack on the street side of the unit. Are one of these the fresh water tank drain or are they both just low point drains? They supplied us with a stack of manuals for all the appliances and accessories but nothing on the unit itself. I can't believe you have to break through the underbelly covering to drain the water tank. Please help. I did pump out all the water I could with the onboard water pump and filled the fresh water tank with about a gallon of anti-freeze.
