Old 10-27-2009, 09:13 PM   #1
TulsaSteve's Avatar
BlueOX TigerTrak
I'm consider a set (front and rear) of TigerTrak track bars as an upgrade for my 2007 370XL.
Any experiences with these or other track bars on the Georgetowns?
TulsaSteve is offline   Reply With Quote
Old 10-28-2009, 06:46 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
The only thing we've added is Firestone Air Springs but I'm not sure if the rating is still the same as when we bought ours. They really helped with the side to side rocking when a big truck goes by. Other than those everything else is Ford factory installed.
http://www.truckspring.com/VSearchResults1.aspx
They sell all types of upgrade suspension stuff.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-28-2009, 08:37 AM   #3
ronhanson's Avatar
Ford has the front track bar standard on the 2006 and newer F53 chassis. There was no 2005 chassis year so you might want to check your chassis date and take a peek under there. I doubt a different one would be much of an improvement.
My 2008 chassis has one and I have no major complaints about the handling except in very high cross winds ill get the tail wagging the dog. A rear track bar may help with that and is on my wish list but low priority.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 10-28-2009, 05:56 PM   #4
TulsaSteve's Avatar
Thanks for the feedback. Per my VIN, my chassis appears to be a 2006. I'll take a peek to confirm the front bar.
My rear gets pushed around pretty bad in the high winds. Living in Oklahoma probably makes my situation a little worse than most.
I found the Blue OX for $499 and it's a "no drill" install so I could do that in the driveway.
Old 10-28-2009, 07:54 PM   #5
ronhanson's Avatar
Wink
Anyone in the central plains from North Dakota to Texas knows what "wind" really means
Ron Hanson
Old 10-28-2009, 09:18 PM   #6
TulsaSteve's Avatar
Exactly! I'm pretty sure I can get upwards of 30 MPG with a proper Okie tailwind.
