Old 10-02-2011, 04:46 PM   #1
blueridg underbelly
Our fitting on the waterheater broke, it leaked all night into the kitchen and the whole sealed underbelly was filled with water. I had to poke a hole in the underbelly to realease all the water. Can anyone tell us if there is insulation in the underbelly and if we need to be concerned about mold? Thanks for any info.
sue3132 is offline   Reply With Quote
Old 10-05-2011, 11:13 AM   #2
I don't know about mold but there is most definitely insulation under there.
If you unscrew the access panel on the side of the docking station in the basement on the road side, you will see it right under the WH.
There is also quite a bit of wood that will probably need to be dried out as well.
45 ACP is offline   Reply With Quote
underbelly
