Old 11-14-2015, 08:51 PM   #11
Looks like he Posted in Post# 1 that it is a 2016 Vengence Toy Hauler 25V! Youroo!!
Old 11-14-2015, 09:07 PM   #12
SKnight's Avatar
Originally Posted by rockfordroo View Post
If this works, then you wouldn't need to pump any water, which takes power of some kind (and after all, you're boondocking!).
My bedroom slide is directly over the water panel, so lifting jugs would be troublesome at best.
I've used this method boondocking twice, since I use a CPAP machine I have to run the generator every day anyhow, plus refilling usually happens pretty late in the trip so I'm already needing a recharge.
I've considered converting to a gravity fill like I used to have, but it's not quite worth it at this point.
Old 11-15-2015, 03:41 AM   #13
bikendan's Avatar
couldn't see his sig line with the FRF app.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 11-15-2015, 06:16 AM   #14
I carry a 50 gallon water tank in the bed of my truck. It's hard plastic. I also have a 45 gallon collapsible water tank. I use a 12 volt pump to move water from both containers into the 5er. We boondock most of the time. If you have that docking station, I understand that you move a lever to fill the fresh water tank or to use a hook up. The pump will pump your water when that lever is in the fresh water tank position. My hard tank is low enough to put my tonneau cover over it. You will need a potable hose to get to the pump and then a potable hose to go from pump to trailer. You will need to figure out how to power the pump. I have a plug in that fits into my 7 pin connection at the back of my truck for that. It sure beats lifting 5 gallon containers. If you really want to get fancy you can use air pressure to move the water also. My hard tank has 2 screw on lids. Both lids have a spring loaded button on the top to allow air into the tank to gravity feed. I converted one to accept an air valve like the ones in tires. Then I used my compressor that I always carry. There might be a problem in that the compressor might not be big enough to pump the water through the fitting in your panel.
Pipeman is offline   Reply With Quote
Old 11-15-2015, 09:25 AM   #15
Toothpick's Avatar
Thanks for all the help guys!
This is what I came up with. I got a 1/10th HP transfer pump at lowes for $88.
Worked like a charm.....
2016 FR Vengeance 25V Toy Hauler
2015 Ram 2500HD CC 4x4 6.7L Cummins
2017 Indian Chieftain Darkhorse
2017 Indian Scout
Toothpick is offline   Reply With Quote
water
