Old 11-14-2015, 06:32 PM   #1
Toothpick's Avatar
Boondocking and water???
How to I gravity fill my water tank? I.e. Bypass the ck valve to gravity fill my fresh water tank?
Thanks,
Mel
2016 FR Vengeance 25V Toy Hauler
2015 Ram 2500HD CC 4x4 6.7L Cummins
2017 Indian Chieftain Darkhorse
2017 Indian Scout
Toothpick is offline   Reply With Quote
Old 11-14-2015, 06:42 PM   #2
Sc00ter's Avatar
There should be two water inputs. On is threaded with a female fitting to accept a garden hose. This is the pressurized street connection. The other should be open with no threads allowing you to simply pour water in. This will be the gravity fill that goes directly into the water tank. I have never seen an rv without the two in close proximity to each other. Hth.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is online now   Reply With Quote
Old 11-14-2015, 06:44 PM   #3
Toothpick's Avatar
I have a hose connection and a tank vent and that's it.....
2017 Indian Scout
Old 11-14-2015, 06:45 PM   #4
Sc00ter's Avatar
Does the manual mention anything?
2015 puma 295bhss
Old 11-14-2015, 06:57 PM   #5
SKnight's Avatar
He probably only has the connection for connecting a hose and filling with pressure, that's what I'm stuck with.
There's a couple of ways to address this, some folks get a separate water pump and connect that way, then use a bladder tank in their truck bed to haul water.
I use what I already have with six, six gallon potable water totes. I then use my onboard winterizing valve and winterizing hose to draw from the totes to my regular onboard water pump. I use my outdoor spigot and hose connected to the water fill connection and simply open the cold valve. Takes a few minutes per tote to pump it into the water tank.
Once done I turn the valve from winterizing to normal and I'm done.
Old 11-14-2015, 07:05 PM   #6
Ashley's Avatar
Universal Docking Station???
Do you have the "Docking Station" a lot of the manufacturer's are using now? If so maybe this video will answer your question. Yes, I know it shows a Primetime unit, but this setup appears to be fairly common across different makes and models.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 11-14-2015, 07:48 PM   #7
Didn't see what unit the OP has, but many FR products do not have a fill port for fresh water other than the water hose inlet. Here are some ideas:
V-cross Vibe 823VDS5 no gravity fill fresh water
pjnlorrie is offline   Reply With Quote
Old 11-14-2015, 08:28 PM   #8
I think one reason they may be doing this is so no one can dump something into your water tank via the gravity fill (sand, sugar, or worse).
I suspect the manufacturers don't want to buy two different connectors, so they are using the same "standard" city water connector for the FW fill as they are for the actual city water connection, i.e., there's a check valve in it (even though it's not needed for the FW tank fill). If so, I'm guessing your attempts to "gravity fill it" from a tote just doesn't have enough pressure to open the check valve. I'd check the connector and if it has a check valve, I'd suggest trying to remove the check valve from the connection (some are "replaceable" and therefore should be removable). Another option is to replace it with a connector without a check valve. Here's one without a check valve (there are other models available):
Amazon.com: JR Products 9691-300-023 City Water Fill: Automotive
If this works, then you wouldn't need to pump any water, which takes power of some kind (and after all, you're boondocking!).
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 11-14-2015, 08:36 PM   #9
bikendan's Avatar
Maybe the OP will come back and post what model RV they have.
Every trailer I've seen has a FW fill port.
Don't know about motorhomes.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 11-14-2015, 08:47 PM   #10
Sc00ter's Avatar
2015 puma 295bhss
water
