Old 03-31-2009, 12:47 AM   #1
Send a message via Skype™ to stevo
Brake and turn signal wiring
I have just ordered a Windjammer TT.
I live in New Zealand and we require seperate brake and turn signal lamps.Can someone confirm that the standard lamp set up for Forest river is a single twin filiment lamp for brake and turn.
stevo is offline   Reply With Quote
Old 03-31-2009, 07:52 AM   #2
MtnGuy's Avatar
stevo, from this side of the world !!
I am not fimilair with the Windjammer, but most travel trailers that I haved worked with use the same filiment for the brake and turn signals, and another smaller filiment for the running lights, all in 1 bulb.
I think there are adapters available to make this work on vehicles with seperate systems, and I think (again ) that most foreign vehicles used in the U.S. have this built into their electrical system when there is a factory 7 pin plug installed.
Hope this helps.
Old 03-31-2009, 10:15 AM   #3
NWJeeper's Avatar
I think there are adapters available to make this work on vehicles with separate systems, and I think (again ) that most foreign vehicles used in the U.S. have this built into their electrical system when there is a factory 7 pin plug installed.
Hope this helps.
Correct on the adapters. Although I don't pull trailers I do pull two different Jeeps. Our Wrangler is wired like a normal trailer and thus requires no converter box. However, our Liberty is set up with separate brake and turn bulbs and I had to wire a converter onto it for towing it behind the motorhome.
You should have no problem finding the converter if you need it, they are all over the net but there are different types so be sure if you do buy one that you get the correct one.
We would love to visit New Zealand somtime but the drive is bit of a problem
Ed & Wendy
www.nwjeepn.com
Old 03-31-2009, 11:11 AM   #4
milzat's Avatar
Hello, Stevo.
Yes. One bulb, incandescent.
Stop, Turn and Tail Light
milzat is offline   Reply With Quote
Old 03-31-2009, 10:57 PM   #5
Thanks for your help have found a converter to do the job
Cheers
Old 04-01-2009, 06:22 PM   #6
Knower of Some Things
I do have one concern, although not related to tail lights: What is the width of the camper, and what are the limits on width that can be titled in New Zealand? I've heard some horror stories on that one, whether or not they are true...
PumaPro is offline   Reply With Quote
Old 04-02-2009, 12:40 AM   #7
Hi Puma,
Good point it is a real issue for class A motorhomes as its almost impossible to source one under the allowed 98.4 inches.
The trailer that I have ordered is 96" so we just make it!
Currently they allow the entry doors on"the wrong side" in Australia they dont!
Our biggest issue is the lighting and lenses on the lights.
We are supposed to have white scare lights,and orange turn signals.
As we are buying through a wholesaler i guess we will need to sort out the local issues.
"Thanks for the heads up"
Cheers
Old 04-02-2009, 07:40 AM   #8
Welcome to FRF!!
Good luck with your purchase.
BTW that would be the "correct side" for the doors.
aintgotnun is offline   Reply With Quote
brakes
