Forest River Forums
Sunline User Photos
Old 12-21-2011, 08:14 PM   #11
The break-a-way switch cable is designed to be pushed back into the switch-just make sure it's bottomed out when pushed in.You won't have any problems with this.When I work on electric brakes,I pull the cable out to make sure the brake-a-way system is working properly,then push the cable end back into the switch with no problems occuring.
09grizzly1 is offline   Reply With Quote
Old 12-22-2011, 10:23 AM   #12
Alpineman's Avatar
Thanks 09 grizzly! The only other problem I have had is to get the tv and Xm radio to play on speakers I have tried all the inputs on the Genisis tuner and no sound ?thoughts?
Alpineman is offline   Reply With Quote
Old 12-22-2011, 02:11 PM   #13
Rebel702's Avatar
TV input is AV2 (be sure to use AV, not AU). Speaker button A should be your inside speakers. B is our bedroom speakers and C is outside. Can you give more detail about what you have tried?
Also, Bob Fields is a contact and is active on this forum.
bfields@concertone.com
574-343-1165 - Elkhart Office
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 01-07-2012, 07:23 AM   #14
We have a 2012 Rockwood 8314BSS and the battery disconnect is located at the top of panel where the light switches are located by the door. It is a push/pull button.
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 01-07-2012, 08:06 AM   #15
Fire Instructor's Avatar
Originally Posted by Alpineman View Post
I think there is no disconnect as I could not find it near fridge or propane. Thanks for the help. Need to see if brakes are working after pulling out the breakaway wire it snapped back in harness no problem but still worried it may have done something.
If the breakaway cable is still activated, your problem now will be no 12v, power. The breakaway cable activates the brakes by utilizing the power from the 12v. battery to apply brake power at "full brake" (as if you were standing on the brake pedel)!
This applys an immediate stopping power to the TT axle brakes, but it draws the power from the battery quicker than the converter can replenish it, if you are plugged in.
Every season, it seems, we see a posting from a newbie camper who tried to use their brakeaway cable to secure the TT, rather than wheel chocks. A dead battery is the LEAST of the damaging thibgs that occurs. What's worse, is that it can also burn-up the electro-magnets that acticates the brakes, leading to a reatively expensive repair. (The parts are relatively cheap, but the dealers kill you on the installation, as the wheels, bearing packs, and brakes all need to be pulled apart.)
Be safe, and Everyone Goes Home!
Fire Instructor
2004 RAM 1500 4x4 Quad Cab w/Hemi, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 03-22-2012, 02:51 PM   #16
Alpineman's Avatar
Just moved trailer and it worked fine after resetting brake away pin,
Close [X]
