12-18-2011, 12:45 PM
Brake breakaway cable
I have a 2012 Rockwood RV, the break away cable for emergency brakes pulled apart while unit was parked I just put it back in clip will it still work ok or does it need replaced?
12-18-2011, 12:47 PM
If it just pulled out, and you can push it back in, it should be fine.
2007 Surveyor SV291
Equil-I-zer hitch
2005 Durango Hemi
12-18-2011, 12:53 PM
Thanks! It pulled apart when I was unhooking from truck I just clipped it back in seemed to work fine. I will watch when I tow again to ensure brakes are free.
12-18-2011, 12:58 PM
One last question I believe this unit has a quick power disconnect instead of unhooking battery but I could not find the disconnect? Thought?
12-18-2011, 01:33 PM
Moderators' Assistant
it would help if you posted the model number you have.
most of us include it in our signature.
i know of some of the Rockwood hybrids having a battery disconnect switch for 2012. but don't know about the regular TT line.
Dan and Shawn and Zoe the Wonder Dog
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
12-18-2011, 03:10 PM
2702ss is the model. They said it had this quick disconnect but like I said I can't find it .
12-18-2011, 03:56 PM
2702ss is the model. They said it had this quick disconnect but like I said I can't find it . Thanks
here's a link to a pic of biken201's Roo and his battery disconnect switch.
it's the silver knob under the fridge, to the right of the fuse panel.
Battery Switch
12-18-2011, 04:11 PM
My Windjammer 3002 battery disconnect is inside the propane compartment in front. It is a silver knob that you push in to disconnect. Can you follow the battery wires back to find the disconnect. Maybe in the front compartment?
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
12-19-2011, 08:40 AM
I think there is no disconnect as I could not find it near fridge or propane. Thanks for the help. Need to see if brakes are working after pulling out the breakaway wire it snapped back in harness no problem but still worried it may have done something.
12-19-2011, 09:21 AM
if the battery was hooked up and charged, something probably happened.
if no battery power, should be fine.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 263 |
| 20 members and 243 guests |
| Ace Barker, BigDogD, DAISY BOYKIN, dangerranger363, darkcloud, DSN46, elkhntr4evr, fonzie, h20ski, ladyff1481, Leathergypsy, mrthumper24, Namchief, navypoppop, nrcamp, RvBill3, Unruly, Vernk, wolfpack21643, wtrider |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
