Old 10-18-2010, 02:20 PM   #11
Infractee
Thanks for everybodies quick and helpful replies! It is greatly apreciated.
RZ
RhoZeta is offline   Reply With Quote
Old 10-18-2010, 03:54 PM   #12
grhodes50's Avatar
Originally Posted by RhoZeta View Post
Sorry for the confusion, should have read ran water at each valve/tap. Only trying to run it on elec right now, have not turned on gas. That will be after I get the water heater working on electric.
One more thing to look out for. If you heat your water by elec, then switch to gas, the red light may not come on and the water heater may not try to light. It's because the water in the tank is already hot. After the water cools the gas side will operate normally. I ran into this a couple of times before NWJeeper was able to helped me out.
Gary & Trish
2018 Nights Camped - 5
Old 10-18-2010, 06:05 PM   #13
Infractee
Thumbs up
Found it!!
Lower aft end of WH area, under a lot of pipes and wires.
It even has an R key to safe it in the off position, for when it is winterized I am assuming?
Pulled the pin, hit the switch and after about 5 minutes warm water started flowing.
Thanks again for every body's help!
Old 10-18-2010, 06:23 PM   #14
I have one suggestion and this is what I do and it works for me, after camping I turn the breaker off in the breaker panel to the water heater this way I know that the water heater is off.
When we go back out for camping and connect the city water up and turn it on I then open all hot water sides to all of the sinks to make sure a steady flow of water is present then I turn the breaker on to the water heater. This work every time and while driving away I don't have to think back and try to remember If I turn the switch off to the water heater.
Old 10-18-2010, 08:31 PM   #15
Infractee
Thanks for the tip, I am currently writing a pre and post flight check list to be done before towing to and during setup at camp and then breaking camp/towing home and subsequent unloading and trip back to the hangar.
Water heater on and off W/purge will be on them.
I will have my checklist and Me Wife will have hers.....
Old 10-18-2010, 08:39 PM   #16
Infractee
A quick picture of the new toy... more to come.
Old 10-18-2010, 09:26 PM   #17
Pheeew ! My fingers were crossed for you ! I am glad it was in the off position. I always turn it off when I am done camping regardless of whether I have water in the water heater tank or not. Just in case it leaked or something and it is dry and might be harmed when I plug in the power, as that is the first thing I do when I am setting up.
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 10-18-2010, 11:07 PM   #18
Very nice camper .Looking forward to more pics. Good luck and enjoy
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 10-19-2010, 09:44 AM   #19
rockwood06-I just picked up our new Signature Ultralite 8296SS this past weekend and during the walkthrough with the dealer, the tech mentioned that some people turn the heater off by using the breaker, as you do. However, he said this could weaken the breaker over time and it may start to trip on its own, unecessariily. I just thought I would share that.
Time2Tow is offline   Reply With Quote
Old 10-19-2010, 09:51 AM   #20
MtnGuy's Avatar
Also be careful that something else is not wired into the same breaker. On my Surveyor, the water heater and the fridge use the same breaker.
