Old 07-01-2012, 11:23 PM   #1
Broken entry stairs
A rivet(or bolt?) on our manual stairs broke today almost causing an injury to my daughter in law. Does anyone know what to use to replace this with? I have put in a 1/4 bolt as a temp fix but the steel in the bolt is too weak and bends. Any ideas or fixes out there?
seatosea
'04 Dodge 3500
'11 Flagstaff 8528RLWS, Hijacker 16k slider
HTR member Nights camped 2010 -115, 2011 -40 , 2012 -41, 2013 -86,
seatosea is offline   Reply With Quote
Old 07-02-2012, 10:01 AM   #2
Chewie's Avatar
Try to find a stainless bolt that's higher rated than what's in there now, grade 5 or 8 should be more than enough. Use flat washers on both sides and then a nylon lock nut so it won't back out but still be loose enough to fold up and operate as normal. Use all stainless hardware so it won't rust again. Glad to hear she didn't get hurt.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 07-02-2012, 11:08 AM   #3
IT Guru
Send a message via AIM to jsilvius Send a message via Skype™ to jsilvius
we had this issue last year.
We took the camper back to the dealer and they fixed the step, and it broke again 2 trips later when my wife stepped on it.
We went to Home depot and got a grade 8 bolt and washers like Chewie suggested, but we also noticed that the a couple of the bolts that attaches the entire stairs to the camper where loose so we tightened those up. Since then (4 more 2/3 days trips) we haven't hand any issues (knock on wood).
2006 Flagstaff 831FKSS
2005 Dodge Ram 2500 SLT 5.9L Turbo Diesel Quad Cab
1 - DH (me); 1 - DW (Tee); 1 - DS (Jarod, 12)
Nights Camping: 2010 - 15; 2011 - 7; 2012 - 9
jsilvius is offline   Reply With Quote
Old 07-04-2012, 01:36 AM   #4
Derick441's Avatar
The same thing happen to my brother and sister in-law on there Rockwood the first one we about 3years ago and the 2nd one happen at Christmas both times I had some closet bolts in my tool box works great. Just fyi closet bolts are the bolts that hold your toilet down to the floor in your home.
Derick441 is offline   Reply With Quote
Old 07-04-2012, 06:20 AM   #5
That was the first mod I did to our 12 Flagstaff 8528 when we got it home. Replaced all the rivets on the steps with 5/16" gr 8 bolts, washers & nyloc nuts. Can't believe any mfg would use rivets. FR needs to find a better supplier.
Old 07-04-2012, 08:30 AM   #6
Replace with grade 8 5/16" bolt and nyloc nuts
easy fix and better then what you had
SALTY is offline   Reply With Quote
Old 07-04-2012, 11:09 AM   #7
As an emergency fix, they will work great, but all I have seen are brass and won't last long. Gr 8 5/16" are much better and will last until the steps themselves start to elongate in the holes.
