03-16-2016, 10:15 PM
Broken steps
Top pivot on Main steps broke Just wondering if anyone else has had this issue. Looks leverage broke upper tube
Unit is a 2014 Rockwood 2604WS
03-16-2016, 10:20 PM
Left Coast
usually the rivets fail......when they do, replace with a grade 5 or better bolt and ny-loc nut. some people use a step support also
03-17-2016, 01:21 AM
My steps on our Rockwood did the same. What I did was drilled out and put a Allen bolt and nut. Allen are harder than must nuts and bolts plus I had to watch my space to make sure it worked.
03-17-2016, 05:12 AM
We bought a new Wildcat Maxx in 2014 and traded it for a longer Maxx unit in 2016. When we first climbed the steps in our 2016 I couldn't believe how flimsy the steps felt compared to the 2014. I use 2 step supports, side by side, about 10-12' apart between the bottom step and the ground. This makes the steps very solid and should save them from being over-stressed/broken. So far, so good!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
03-17-2016, 06:13 AM
The more steps,the more Leverage! Our steps still have the O/E rivets,but we have had the Steps supported since Day 1,Lots of Leverage Movement when going In/Out,Without Step Supports! Youroo!!
03-17-2016, 07:02 AM
That's because they say "Flexco". They evidently are living up to the name that's on them.
I figure by the 2018 model year the steps will be either made from luan plywood, cardboard, or no steps will be provided. They'll just give you one of those plastic step stools that cost $.99 at Wally's.
03-17-2016, 07:18 AM
Left Coast
Rope ladder or cargo net
Sent from my XT1080 using Tapatalk
03-17-2016, 07:28 AM
Try these Bad Boys! Youroo!!
03-17-2016, 07:41 AM
Left Coast
Pogo stick would be handy there...
03-20-2016, 11:28 AM
I have a 2014 Silverback 29RE. My steps top tube broke as you described. The steps were replaced under warranty.
Andy
03-25-2016, 10:14 AM
Wouldn't it be nice to have things designed to last longer than the warranty period,
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
03-25-2016, 10:38 AM
Left Coast
Well, at least we now have a pattern!
03-25-2016, 03:10 PM
My unit has a 3 stepper. One of the step rivets gave way last year in Wisconsin. Replaced the rivet with a 1/4 x 3/4 x 20 stainless steel bolt with a stainless steel nylon lock nut. Last week I discovered another rivet was ready to go. I drilled out all the existing step rivets and replaced them all with stainless steel bolts. I also use a step support under the steps.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
