Old 07-17-2016, 12:14 PM   #1
Building a tool kit
I'm new to the RV world. I've gained a lot of knowledge on these forums .. thanks for all your help so far.
I'm building a tool kit -- I want to save weight while still having all the neccessary tools in the event something goes wrong.
Can anyone offer any advice on building an efficient kit that doesn't weigh a ton and covers all the basics plus some more advanced issues that may arise?
I'm running a 2014 FR3 25DS with 3,400 miles on it.
Does Forest River generally use Standard or Metric sizes?
Are there any specialty tools that a new RVer like myself may over look that I should get?
2014 FR3 25DS
teamjendy is offline   Reply With Quote
Old 07-17-2016, 12:17 PM   #2
fonzie's Avatar
This should keep you busy reading and getting most of what you are looking for....
https://www.google.ca/search?q=tool+...iIGsmweMPcnKAD
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 07-17-2016, 12:21 PM   #3
Ford Idaho's Avatar
#2 robertson bit and a bit screwdriver.
Zip ties and Gorilla tape.
These fit both metric and SAE.
http://www.googleadservices.com/page...QzTkIJw&adurl=
Old 07-17-2016, 12:37 PM   #4
Stop by China freight store and pick up a tool set. They have several setups. You can probably get it for about $50 bucks w/ coupons, etc. The quality will suffice for on the road repairs and its all contained in a tool chest organized for easy access.
Old 07-17-2016, 01:10 PM   #5
grumpy0374's Avatar
X2 on a good multi bit screwdriver and a few #2 robertson square drive bits, including a few longer ones. They will fit probably 75% of the screws keeping your rig together.
Unless you plan on doing repairs to the chassies of your rig, there is no need for anything larger then a 3/8 inch drive socket set. No really large nuts/bolts in the "box" of an rv.
A good pair of pliers, needle nose pliers, pair of vice grips, and a small and medium adjustable wrench. Pair of wire cutters.
Hammer and rubber mallet.
Set of wrenches.
A roll of stainless steel wire (like bailing wire, but ss)
Duct tape. Assortment of and including some 18-24 inch wire ties.
An assortment of a few dozen screws (wood, metal) and some nuts/bolts/washers. All the stuff I carry is stainless steel.
Extra fuses and mini breakers in sizes your rig uses.
Some good ole rubber bands, tacks, some binder clips.
A bottle Weldwood Contact Cement.
Small pry bar, like a 12 or 18 inch length.
You'll add to or subtract from based on your needs as you run across a problem or two. But no need to go nuts. I have a friend who carries a full set of tools, and I mean a FULL set, in his class c. Probably weighs 300 lbs, in addition to his compressor, jacks, air tools, ect. Way overkill.
If you get to the point where you need 1/2 inch drive sockets, air drive tools, and large size wrenches, you probably need a tow.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 07-17-2016, 01:21 PM   #6
A free multimeter from Harbor Freight and gorilla tape instead of duct tape.
Epat is offline   Reply With Quote
Old 07-17-2016, 01:30 PM   #7
Hoglou's Avatar
A friendly suggestion from a biker. only use the tool bag that you (develop) carry in the rv. add and subtract to it. its a hoot to see someone on an ultra HD with torx and sockets that dont fit anything on the bike. i would focus on parts and not tools, like 15 amp blade fuses and a spare water filter housing. things that will send you home or to the hotel..
can you take your hw element out without going to the garage?
Hoglou westGA
KM4HQQ 146.640mhz
Old 07-17-2016, 01:33 PM   #8
World Wide Wanderer
wahoonc's Avatar
  • Multi-meter (VOM)
  • Screw/nut driver with interchangeable tips (Klein 11-n-1 is mine)
  • Moisture meter
  • Leatherman multi-tool
  • wire strippers
  • pliers
  • pump pliers
  • vise grips (small and larger)
  • socket set
  • electrical tape
  • aluminum tape
  • duct/gorilla/zip tape
  • hammer
  • cold beer
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 07-17-2016, 01:37 PM   #9
2012 Solera
Add super glue with accelerator (https://www.amazon.com/Bob-Smith-Ind...ue+accelerator) and Goop.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-17-2016, 02:03 PM   #10
grumpy0374's Avatar
Hoglou brings up a very good point. Bring what you need to fix/repair something that, although simple, could ruin a trip for the lack of a part or tool.
Not talking about a major repair, but as pointed out something as simple as a leak or broken water line can send you home. Just carrying a few lengths of pex, an inexpensive tubing cutter, and a few gator type push connections can save a trip, weigh next to nothing, and cost less than 20 bucks. But if it's a Sunday evening, and you have a leak, you just may have what you need to repair it.
Having some assorted electric wire, some connectors and a wire stripper, again, weighs next to nothing, costs 10 bucks, and can save your trip.
Don't worry about little things that can be put off till you get home, like a piece of trim becoming loose, but can you reattach or tie down an awning if necessary? Fuses or circuit breakers to get your fridge or water heater going again?
You don't need 3 inch long decking screws, or 1/2 inch bolts and nuts, but could you repair a simple drawer latch if needed?
Grumpy
