Old 09-10-2019, 10:41 PM   #1
buying 1 1/16 socket for water heater drain removal?
I need to get a 1 and 1/16 socket to drain my water heater (Suburban SW6D). I THOUGHT I ordered the right one from Amazon but it ended up being the Camco socket for residential water heaters at 1 1/2
Where did you get your 1 1/16 socket, and does it really matter as long as I get the right size? (6pt vs 12pt, deep vs regular)
Grimble27 is offline   Reply With Quote
Old 09-10-2019, 10:47 PM   #2
Big Sky KLX's Avatar
Got mine at harbor freight. Use a coupon.
It is a 6 point impact deep socket
2019 Coachmen Clipper 21bh
2006 Chevy Silverado 1500 4x4 5.3
Big Sky KLX is offline   Reply With Quote
Old 09-10-2019, 11:30 PM   #3
That 1.5" socket should work for the element should you ever have to replace that . so store it with the other .
MR.M is offline   Reply With Quote
Old 09-10-2019, 11:41 PM   #4
frank4711's Avatar
yep did it x2
Frank & Cindy ... Rockwood 2888WS Ultra Lite 5th Wheel---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed---Remi & Sage camp pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Goodyear Endurance ... Predator 3500---48 days 2019---Payload 4394
frank4711 is offline   Reply With Quote
Old 09-11-2019, 02:25 AM   #5
I got mine at Lowe's.
Cdj1990 is offline   Reply With Quote
Old 09-11-2019, 05:31 AM   #6
Menards.
Home Depot, Lowes, ACE, any hardware/Lumber store should have what you need.
TheWolfPaq82 is offline   Reply With Quote
Old 09-11-2019, 05:36 AM   #7
Oaklevel's Avatar
Just about any store that sells tools.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 09-11-2019, 06:32 AM   #8
KyDan's Avatar
My LP line runs right in front of the drain plug so I have to use a box end wrench.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 09-11-2019, 06:49 AM   #9
Just a plug...not Anode ? Old TT with just a plug was same way. Box wrench only. New TT with Anode I remove with a socket.
Old 09-11-2019, 07:09 AM   #10
Flybob's Avatar
6 pt or 12 pt kind of depends on how firmly it is in.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-11-2019, 08:54 AM   #11
Just as confused as you
Scrapper's Avatar
If it's the first time removing the drain plug always use a 6 point socket. On my brand new trailer the first time I removed my drain/anode it took me and my neighbor on a 18 inch breaker bar just to get it loose. One to hold the bar + 6 inch extension + socket on the plug and the other to pull on the breaker bar. The plug was overly tight without teflon tape or pipe dope.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 09-11-2019, 12:47 PM   #12
I've never removed mine yet, but my 2 cents would be to get a 6 point socket. I can't remember the last time I needed a 12 point socket. I think those are for square bolts/nuts. When have you seen a square nut (recently).
Jim M.
jimmarako is offline   Reply With Quote
Old 09-11-2019, 01:52 PM   #13
Harbor Freight. I bought a 1/2" impact socket set for dirt since I have an air compressor, but anything will do for this job.
Jim & Renee
2014 Forest River/Rockwood HW 277
Typical season is about 30 nights camping, usually nearby boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
Old 09-11-2019, 03:15 PM   #14
Water heater socket.
Same thing happened to me. I don't think we ordered wrong. Ended going to Harbor Freight. Six point will work better and possibly avoid trouble with the bolt head on your water plug.
When my home water heater needed a new element, I put the Camco that I had received by mistake to use, and it was WORTHLESS - stamped piece of sheet metal tubing instead of a manufactured socket - so I bought another one of THOSE, also..
jjuscg is offline   Reply With Quote
Old 09-11-2019, 03:48 PM   #15
Oldbears's Avatar
Lowes. There are a set of drawers in the tool department where you find individual sockets. Got a 1 1/16" six point for $5 and change.
2019 E-Pro 14fk
"Some people go camping to relax - you should try it."
Oldbears is offline   Reply With Quote
Old 09-11-2019, 03:51 PM   #16
At Home Depot
Home Depot sells individual sockets and has that size for $4-5. Everyplace else wants to sell you a whole set. (Too bad Sears has closed.)
A regular depth socket is fine, although you will need a short extender bar. A deep-well socket is handy because the drain plug/anode rod is heavy at the far end. If you hand-start it using the deep-well socket, you can direct the plug in at the correct angle so it doesn't "droop" and cross-thread (easy to do).
These plugs are generally not very tight, so a 12-point socket is fine. But they are tapered pipe thread and occasionally some gorilla tightens them too tight.
https://www.homedepot.com/p/GearWren...0770/204344399
https://www.homedepot.com/p/URREA-1-...7434/202797137
https://www.homedepot.com/p/URREA-1-...5434/202796601
All three of these are either stocked in stores or free ship-to-store.
Larry
Larry-NC is offline   Reply With Quote
Old 09-11-2019, 03:56 PM   #17
Nope
Jim M.
Jim, square nuts take 4-point or 8-point sockets. Hex nuts take 6-point or 12-point sockets. It's easier to get a 12-point socket or wrench onto the nut or bolt-head, but it's also easier to round off the nut/bolt since there's less contact area.
I have actually had occasion to use an 8-point socket on a really stubborn square-head set screw on an impeller fan.
Larry
Old 09-11-2019, 04:12 PM   #18
I've got the right socket. The real trick is getting that plug back in once you drain the tank. What a PITA!
Luke Moseley is offline   Reply With Quote
Old 09-11-2019, 04:17 PM   #19
KyDan's Avatar
Aluminum tank plastic plug no anode.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-11-2019, 04:21 PM   #20
Retired Old Fart
dward51's Avatar
Get the 6 point if you have the normal plastic plug. It's easier to round the corners of the plug over with a 12 pt than the 6 pt.
And if you have an impact wrench socket set, you probably already have a socket that will work.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
drain, heater, water, water heater
