Old 05-08-2012, 09:37 PM   #11
Thanks very much for all the great ideas! Since I seem to gravitate towards doing the hardest way possible, I think I will go with the idea of drilling out the hole for an 1/8" dia. dowel and then drilling a pilot hole. With an 1/8" dowel, no one will be able to see it. Judging by ebay and Amazon, they seem to be a crafts store item.
Some toothpicks and glue would be a good idea too.
Hadn't thought about a potential split in the core wood. In that case, a fatter screw would just make it worse.
myredracer is offline   Reply With Quote
Old 05-08-2012, 09:53 PM   #12
caper's Avatar
Don't waste your time with the 1/8" dowel just us the toothpicks and glue. works every time. I use the same method at home as well as in the TT.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-08-2012, 11:58 PM   #13
Mountainmanbob's Avatar
Originally Posted by myredracer View Post
I guess some screw jockey at the factory rammed them in too hard.
no big deal
easy fix
two tubes of JB Weld Quick Set
small piece of a tooth pick into hole
put a very small dab JB into hole
very small amount JB around screw threads
do not put screw into hole very tight
good as new
can still be broken loose later if needed
not your case
RV's are known for screws coming loose
this fixes them once and for all
Mountainmanbob is offline   Reply With Quote
Old 05-09-2012, 04:27 AM   #14
hotrodj125's Avatar
YUUUUP, toothpicks and glue works great!!!!!!!
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 05-09-2012, 07:26 AM   #15
trudinator's Avatar
Everyone beat me to it. Toothpicks and wood glue work every time! And it's a cheap fix.
2012 Rockwood 8293RKSS
trudinator is online now   Reply With Quote
