Old 05-08-2012, 10:04 AM   #1
Cabinet hinge screws are loose.
Have only used our TT 3 times to date. The screws on one of the lower cabinet doors are loose already. I guess some screw jockey at the factory rammed them in too hard. Is there an easy fix for this? I would go to HD or hardware store and buy some longer/fatter ones but to start with, they are oil rubbed bronze color which limits the selection. They are also oval head type which further limits availability, if I want to be picky and match them up 100%.
Is there a screw source out there somewhere that has an oversize screw like this? I think I want a 3/4" x #6 screw. I am guessing the the existing screws might be #5?? At the worst case, I could always go with a long screw like 1-1/4" and screw through into a small wood block behind the cab. face.
I saw some 3/4" x #6 ORB screws somewhere the other day but I had to buy 500 or so. What would an RV repair shop do?
myredracer is offline   Reply With Quote
Old 05-08-2012, 10:12 AM   #2
Toothpicks & glue. Youroo!!
Old 05-08-2012, 10:20 AM   #3
Steve Jackson
sideout1961's Avatar
I had the same thing happen on mine too. One of the screws ripped right out. I took the door off and found that the hinges were so tight up against the door panel that they would hardly move. I just put.fatter screws in they don't match but I will try to find better ones. I found hhis on our first trip out with our new trailer.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 05-08-2012, 11:04 AM   #4
Anacortesians
The cabinet hinges in our s&b kitchen work loose on a regular basis. There's no obvious vibration or anything causing it. I just have to go round and cinch them tight again every couple of months.
Frank and Eileen
No longer RVers or FR owners
Old 05-08-2012, 11:15 AM   #5
If you get them before they get too loose this has worked well for me. Take the screw out, cover the threads with Gorilla glue and re-insert the screw. They will stay put but you can still take them out if you have to.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 05-08-2012, 11:45 AM   #6
DAISY BOYKIN's Avatar
Round toothpicks
I use round tooth picks. I insert the tooth pick into the hole, break off flush with cabinet surface, insert the tooth pick again until you have filled the hole with the tooth picks always breaking off flush with surface. Then you just insert the screw until snug.
A very simple fix!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 05-08-2012, 11:59 AM   #7
camper_Lucy's Avatar
I would not recommend using a larger screw to fix this. What generally happens is that whoever put the doors on was trying to save time or didn't know what they were doing and did not pre-dill the hole, that causes the wood to split in the hole and the screw loosens up over time and use. A larger screw may/will split the wood further and cause a bigger issue and still be loose.
You can either, use glue and the same screw, or epoxy to fill the hole and after it hardens dill a pilot and reinsert the screw.
I have seen where individuals have split the entire board by not drilling a pilot, or by using a larger screw in an attempt to fix, at that point you have to replace the board or the entire cabinet depending on the location.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 05-08-2012, 02:15 PM   #8
Gotago2's Avatar
Get dowel slightly larger then hole(1/8-1/4) drill out hole so dowel is tight fit. Put glue in hole and insert piece of dowel flush to face of cabinet. After glue dries drill pilot hole, put drop of glue on screw and screw into hole. Do not over tighten, do by hand not power driver.
Norm & Paulette
Neverland where growing-up is optional.
2011 Coachmen Mirada 35DS(36") pulling 03 Nissan Frontier
Gotago2 is offline   Reply With Quote
Old 05-08-2012, 02:32 PM   #9
Fire Instructor's Avatar
I use either toothpicks or wooden matchsticks with Elmers wood glue.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 05-08-2012, 03:24 PM   #10
Steve7575's Avatar
I also have used toothpicks and glue. Works every time.
Steve7575 is offline   Reply With Quote
