Old 07-07-2010, 06:49 PM   #1
backin15's Avatar
Cable/satellite jacks
I have two cable connections on my Flagstaff, one for cable and the other for satellite. We went to a campground this weekend with cable and I connected to the cable jack. I connected the TV to the cable/sat jack and the TV would not find any stations. I switched to the satellite connection and it worked ok. I took a look at the back of the TV jack and both cables connect to the tv/cable connection. My assumption is the cable from the tv jack to the outdoor connection is severed or not connected at the outdoor jack. I also assume the only difference is the satellite cable is a higher quality than the regular cable. If so, is there a reason for concern and should I just keep using the satellite hook up for the cable tv sites?
backin15 is offline   Reply With Quote
Old 07-07-2010, 09:58 PM   #2
milzat's Avatar
Cables, at the outside connection, were most likely switched when installed at factory ?
milzat is offline   Reply With Quote
Old 07-08-2010, 10:17 PM   #3
backin15's Avatar
Since both cables terminate at the same indoor connection shouldn't I get a signal off either outside connection?
Old 07-09-2010, 10:06 AM   #4
NWJeeper's Avatar
Do you have a signal selector switch box? We have to push a button for the input we want for each TV on a digital switch box.
Ed & Wendy
www.nwjeepn.com
Old 07-09-2010, 05:22 PM   #5
backin15's Avatar
Nope, I just have a wall jack with two coax terminals. One is for the amplified signal for the rooftop antenna, the other is labled sat/cable and both cables connect to this terminal.
