Work your way backward.....Take a cable inside and connect to port listed as cable, then take other end outside... Using ohm meter, touch center of cable you just took out with one meter probe, and use other probe to touch each connector center...When you get a reading, you've found the right hook-up......Then using menu on tv, switch to cable...Scan for channels
