Old 06-18-2010, 09:08 PM   #1
52Dodgeman's Avatar
Calgon
I have read several post recommending adding Calgon Water Conditioner to the black and grey holding tanks. I have been unable to locate the liquid Calgon locally and have purchased the powder. I plan to pre mix a 1/2 cup with water and add to the tanks. Has anyone else tried the powder?
52Dodgeman is offline   Reply With Quote
Old 06-18-2010, 09:23 PM   #2
milzat's Avatar
Calgon Liquid Water Conditioner would be found in the Beauty Aids Dept. of most discount stores, including Wally World.
milzat is offline   Reply With Quote
Old 06-18-2010, 09:39 PM   #3
I have found mine at Kroger in the laundry section.
Hokiehall is offline   Reply With Quote
Old 06-18-2010, 09:43 PM   #4
52Dodgeman's Avatar
Checked Laundry and cosmetics at Walmart and HEB. Only able to find the powder at HEB. Maybe the liquid is not sold in Texas?
Old 06-18-2010, 09:48 PM   #5
milzat's Avatar
Also found in the Home Care dept. of WM
Old 06-18-2010, 10:07 PM   #6
I used the powder...2 cups dissolved in 3 gal hot water...hope it works...
masonga is offline   Reply With Quote
Old 06-19-2010, 06:34 AM   #7
Herk7769's Avatar
Just make sure
Its the conditioner and not the soap.
The conditioner is what coats the sides of the plastic and makes it "slippery" so stuff don't stick and slides right off. 3 gallons of water is perfect (10% of your tank capacity or more), but cold water and ice is the ticket.
The first time you use it I "highly recommend" two bags of ice cubes (or chips), a cup of laundry soap (liquid works here) and a 30 minute drive before you dump. The ice knocks the stuck on crud off the tank walls.
The water should run BLACK if you have a clear elbow on.
That is the "stuck on" composted stuff leaving your tank.
HAM CALLSIGN - KC3FFW
Old 06-19-2010, 07:52 AM   #8
Proud Member
It was hard to find, but I found the liquid Calgon on the bottom shelf at Wally World underneath and just left of the fabric softeners on the laundry detergent isle. To make it harder to find, they had only one bottle facing the shopper.
Also, I don't bother with the Calgon in the grey tank. I only add it to the black tank. The grey tank is already full of soapy water anyways.
Jim P.
2008 Surveyor SV-291
2003 Ford 4x4 Expedition
Reese SC WD System 800/10,000 lbs
1976 Cessna 177RG
Wife, son, twin daughters, and mother
red.jimbo is offline   Reply With Quote
Old 06-19-2010, 12:43 PM   #9
Herk7769's Avatar
Agree with no Calgon in Gray
Bleach in the gray tank helps keep smell down.
Old soap is stinky over time.
Old 06-19-2010, 09:55 PM   #10
52 Dodgeman, I found the liquid calgon at both "krogers and Randalls" in Houston. I use 2 caps of calgon and 1 cup laundry detergent powder in both black and grey tanks. No problems and no smelly stuff. The wife says it has a pleasant smell. Happy camping !! Jeff Carey
Jeff Carey is offline   Reply With Quote
