Old 09-27-2015, 03:34 PM   #11
Originally Posted by Ford Idaho View Post
I have read where some people remove the filter and replace it with an empty water bottle so you no not need to use as much AF, ping pong balls would likely work as well.
Great tip, Mr. Idaho
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 09-27-2015, 04:00 PM   #12
ColoradoRick's Avatar
When I had a filter (last winter), I used an empty Snapple bottle, with the lid on, to fill the inside of the filter during the winter...fit perfectly. (I've since removed the filter and just connected the hoses.)
Did you get it off? If not, this handy filter remover (designed for automotive oil filters) should come in handy, can be found at an automotive parts store or Harbor Freight:
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 09-27-2015, 07:57 PM   #13
We have a similar canister filtering system in our house, and they tend to stick hard as well. One trick I've found that works is to some of the plumbers silicone lube on the O-ring. Keeps it from drying out at the same time stops it from sticking hard.
2009 Salem PT 403FB
2005 Ford XLT Supercrew
Cookies & Chips is offline   Reply With Quote
Old 09-27-2015, 08:00 PM   #14
As others have said, turn off city water, turn off pump -open a spigot and once the pressure is relieved it should come right off. I just open my outdoor shower and let it run on the ground. Once it stops, filter housing turns easily.
2015 Georgetown 351DS
JohnGalt1061 is online now   Reply With Quote
water, water filter
