Old 05-21-2018, 12:56 PM   #1
Can't get water heater to work on either electric or propane
Hi
This is our first trip with our new Sunseeker 2860 motorhome. All that comes out of our hot water faucets is cold water. There is plenty of water flowage from faucets. It doesn't matter if we have the electric or gas switch on (the propane tank is open). What are we doing wrong? Thanks. Silas
SilasMarie is offline   Reply With Quote
Old 05-21-2018, 01:03 PM   #2
kenandterry's Avatar
New Sunseeker.....first trip...lots of water, but no HOT water.
Id guess the dealer still left the valves in the by-pass position for winter.
Do you know where they are?
Do you know how to do it?
Dealer nearby for them to fix and educate you?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 05-21-2018, 01:06 PM   #3
wmtire's Avatar
X2
This thread may help:
NO (OR LUKEWARM) HOT WATER -Please read first
2011 Flagstaff 831 RLBSS
Ive lost my scapegoat.
Old 05-21-2018, 01:07 PM   #4
Thanks for responding. I did turn one valve which I assumed was the bypass valve after we removed the antifreeze from water lines.
Old 05-21-2018, 01:13 PM   #5
wmtire's Avatar
The problem now, is if there wasn't water actually in the heater when you turned on the electric heating element...then most likely the element is fried.
The propane should still work, but you if you have a Suburban water heater, you might have possibly tripped the ECO/Hi-limit thermostat from dry firing it on propane. You may has to push in the reset buttons....AFTER you have verified there is water inside the tank itself. You can verify by flipping up the Temp and Pressure Relief valve on the water heater tank to make sure water comes out (that let's you know there is water in the tank)
Here is a post from yesterday showing/explaining the reset buttons:
http://www.forestriverforums.com/for...ml#post1814562
Old 05-21-2018, 01:18 PM   #6
wmtire's Avatar
Also if you do have the Suburban brand water heater, then you may want to read this thread:
Suburban's electric switch and much more
Old 05-21-2018, 01:32 PM   #7
And be aware there are a number of ways the manufacturers have come up with to bypass the water heater. You may have 3 valves to turn, or 2 valves or just one.
See page 2 of the attached. Option #1 is the most common.
2011 Traverse LT, 3.6L, FWD
Old 05-21-2018, 03:59 PM   #8
Thanks!
Well, the water is now hot. I didn't have the valves in their proper position, like you suspected. Also two valves were incredibly hard to turn.
Si
Old 05-21-2018, 04:02 PM   #9
wmtire's Avatar
Si
Glad to hear, Si.
If this is perhaps your first RV, this thread may also be of help:
New to RV's helpful hints
electric, heater, propane, water, water heater
