Old 02-28-2016, 09:26 AM   #1
rattleNsmoke's Avatar
Champion 73561 Inverter\Generator - 2000w
I'm considering on of these to do a lil' dry camping this spring. has anyone used one of these cubes and what can it power?
rattleNsmoke is offline   Reply With Quote
Old 02-28-2016, 10:41 AM   #2
The two Champion generators I see are:
73540I 1700 watts continuous, 2000 starting watts. Reduce power output by 3-4% for every 1000 feet above sea level assuming car is properly jetted for that altitude. You'll need two to have ac with reserve capacity for basics.
75531i 2800 watts continuous and 3100 starting watts at sea level. Should be ok at lower elevations but you may want something that has 3000 watts continuous and higher starting watts.
I think that two of the 1700 watt (labeled 2000 watt) generators in parallel would be a good option
Skyliner is offline   Reply With Quote
Old 02-28-2016, 10:59 AM   #3
DougP47's Avatar
You may want to consider the DB noise level of the champion.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 02-28-2016, 11:24 AM   #4
A friend and I have Champion 2000w inverters and like them. Tiny difference in sound than the Honda/Yamaha, if any. As stated, it will not run air conditioning. It will do most everything else, even if you have to stop some items (coffee maker) to run others (hair dryer). We have run ours in tandem for air conditioning. Worked well.
It's a nice quiet machine. I would certainly recommend it for occasional use. For heavy usage I'd prolly go Honda.
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 02-28-2016, 11:24 AM   #5
Do you think I can run my microwave off the 2000w cube if most every other large power robbing device is off-line?
Old 02-28-2016, 11:27 AM   #6
yes
Old 02-28-2016, 11:35 AM   #7
That's good news cause wifey would be a bear without her tea in the AM.
Old 02-28-2016, 11:46 AM   #8
There are charts (Google) where you can see what common appliances pull so you can get an idea what you can run simultaneously. We bought a stainless steel carafe at Wally World to keep coffee hot so could shut down the coffee maker after brewing.
Old 02-28-2016, 12:03 PM   #9
That's great advice. Thanks!
Here's what i found....
File Type: docx Approximate Starting Wattage-Dry Camping.docx (14.2 KB, 58 views)
Old 02-28-2016, 12:52 PM   #10
HONDAMAN174's Avatar
Are you buying a new one or a reman?
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
generator, inverter
