Old 09-14-2010, 10:03 PM   #1
chipmunk in trailer
Picked up a chipmunk on the weekend. WOW what a disaster that was. 5 month old trailer and I had to gut the interior to clean it out.Pulled the underbelly out and found 2 4" holes that were not sealed at all. The rascal built a nest behind our pantry.All tho 2 good things came from this
1- I fixed the ripped heater vent to the bedroom. the dealer told me there was nothing wrong with it(they said it was normal for it to not blow heat at that vent)
2- I have it at a shop having the entire bottom spray foamed. hello protection , good bye rodents!!
I will post pics of the "after" of the underbelly later.
Name:	sept 2010 002.jpg
ID:	3433   Click image for larger version
Name:	sept 2010 007.jpg
ID:	3434   Click image for larger version
Name:	sept 2010 011.jpg
trailraider is offline   Reply With Quote
Old 09-15-2010, 06:16 AM   #2
yvesm's Avatar
Cant wait to see the images after you have the bottom sprayed
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 09-15-2010, 12:03 PM   #3
milzat's Avatar
Goodbye having to get to anything when it needs tending to.
milzat is offline   Reply With Quote
Old 09-15-2010, 12:20 PM   #4
not to worried about it. I would rather have the protection from the rodents. they are way worse.We store the trailer on an acerage. plus the regididty it gives the trailer is great , a lot less flex when on the highway. bottom will be protected other then the slide components(just incase) you know with all the horror stories people say. I havent had issues (knock on wood). but you never know.
Old 09-15-2010, 12:30 PM   #5
milzat's Avatar
Good luck.
Old 09-15-2010, 05:14 PM   #6
bsmall's Avatar
X2 Good Luck with the spray. Just hope you never have to track down any bad wires or connections with the spray applied.....
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 09-15-2010, 06:04 PM   #7
powerboatr's Avatar
chipmunks
i have to laugh, i had never seen one until we moved to a mountain top in north alabama. them little guys got into everything
post some post foam pics, i have a few areas i thought about doing it to,
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 09-15-2010, 07:17 PM   #8
went through everything in the under belly to make sure it was up to my standards(not the manufacturers). once I was happy with it I had it hit with spray. I will have less chance of problems with any wiring now then I would have before it was spayed.nothing is open to get corroded or weatherd or chipmonked.
note* the middle picture is of the tanks*
Name:	trailer underbody 001.jpg
ID:	3451   Click image for larger version
Name:	trailer underbody 002.jpg
ID:	3452   Click image for larger version
Name:	trailer underbody 003.jpg
Old 09-15-2010, 07:40 PM   #9
yvesm's Avatar
What type of foam did you use? Did you do it yourself. I was thinking about getting a spray foam kit from my local lumber yard and doing it myself.
Old 09-15-2010, 08:37 PM   #10
we use line-x at work to do all our spray in liners, he also does the foam spray. i just had him do it for me.
