Old 05-23-2011, 03:15 PM   #1
Clipper 108ST help
Hi,
I purchased a new Clipper 108st in December last year and used it for the first time this weekend at a provincial campground (Canada) but have a couple of questions/problems.
1) Although I was plugged in I could not run the fridge on 120V (didn't work) or use any of the electrical outlets (didn't work). Is there a switch or something I am missing that has to do with the converter. Everything that runs on 12V was fine after I was plugged in.
2) Sorry for my ignorance and my walk through of the camper was 6 months ago, I have no idea how to use the water system - both the sink and the hot water. If anyone can give me using water for dummies regarding this model it would be appreciated.
Thank you and sorry for my city-dweller noob questions.
Kuma is offline   Reply With Quote
Old 05-23-2011, 03:47 PM   #2
bikendan's Avatar
not knowing how yours is setup, it's hard to answer.
you should post a similar question in the Tent Camper section, here at FRF.
for the 120v fridge and outlets, you have to plugged into shore power. can't work off of the battery.
so, it has to be something with the converter. you need to post pics of it or the brand and model number of it.
same goes for the WH, need brand and model number. and are you using city water or the FW tank's water?
